Acer 5920G laptop, can't connect to TV via HDMI
Discussion in 'Laptops & Netbooks' started by The-One, Mar 18, 2008.
  1. The-One
    The-One Member
    Apr 29, 2006
    545
    +23
    Hi all:
    I can't connect my Acer 5920G to my Philips 32PFL. Basically my laptop cannot detect another monitor plugged in. I've changed my drivers, currently 167.58 Vista 32bit tried fiddling with display settings in the control panel and with my nVidia graphics card options (8600m gt 256mb).
    I don't think it's the TV because I have tried connecting it to a Toshiba 37Z as well that that didn't work either.
    Anyone know what's wrong?
  2. bharatgi
    bharatgi Member
    Jun 6, 2005
    431
    +9
    you pressed ftn & f5 to activate 2nd display?
  3. The-One
    The-One Member
    Apr 29, 2006
    545
    +23
    yes I did.
    I have sent this back to Acer, and they've reassembled the laptop and said there was no fault detected when they connected it to their TVs.
    I have now got it back, and it still doesn't work.
    fn+f5 does nothing
    Nvida can't force detect my TV
    tried all 3 HDMI ports on TV
    the only thing I haven't done so far is to try another cable, but this cable worked fine on my friends laptop, it was a Dell, so not the same as my Acer.
    I guess by the lack of replies that my problem is not a common one?
  4. AudioGuru
    AudioGuru Member
    Mar 18, 2008
    213
    +9
    I'ld get back on to Acer and explain exactly everything that you've tried!
    Have you looked in the device manager to see if the hdmi ports are enabled? Just a thought.
    I'm quite new to hdmi on lappys so I'm sorry if that doesn't help much!
  5. The-One
    The-One Member
    Apr 29, 2006
    545
    +23
    An execellent thought & I've just looked through the Device Manger lists. Cannot find the words HDMI in there anywhere, and haven't found anything that looks like it might be for the HDMI.
  6. andyUK101
    andyUK101 Member
    Dec 30, 2006
    1,310
    63
    +128
    I had exactly the same problem with my Tosh - it turned out to be a problem with the audio drivers
    Once i had updated the realtek audio drivers it worked fine - might be worth a try
