Accessing Service menu on Toshiba 36ZP48?
Discussion in 'TVs' started by Free To Air, Dec 8, 2006.
  1. Free To Air
    Free To Air Member
    Mar 22, 2004
    934
    28
    +27
    Could anybody please advise me how to get into the Service Menus on a Toshiba 36ZP48 TV as I need to make some adjustments to the geometry?
    I have tried the below method:
    1. Press the mute button on the remote
    2. Press and hold the mute again whilst pressing the menu button on the TV set.
    The above sequence causes a set of characters to appear in the top left corner of the screen and the letter S in the top right corner of the screen. However, there is nothing that seems recognisable as a service menu. The characters that appear in the top left corner are in 2 rows and are:
    RCUT 0410H
    60H 0110000B
    I need to adjust the screen width to a narrower setting as lettering is getting lost offscreen on the left & right sides of the TV. Has anybody a list of settings with some clarification as to what is adjusted etc for this specific model and a bit of info as to how I adjust them.
    I have the Video Essentials DVD so can use that as a guide but did not wish to make any adjustments until I was clear on what I was adjusting.
    rgds
    moonbase
  2. L00py^
    L00py^ Member
    Sep 23, 2004
    129
    From other poster's many moons ago.
    1.
    After searching some other Toshiba threads I figured out why I was having trouble getting into the service menu.
    Service menu is accessed by using the remote, pressing mute THEN pressing and holding mute WHILE pressing the menu button ON THE TV.
    To get the pattern up, press the SOURCE INPUT button several times (it'll cycle a red, a blue and a green screen before getting to the grid).
    The correct procedure is: Press the mute button once (on remote), now press and hold the mute button (on remote), while holding the mute button press the menu button on the TV.
    Here are some of the available settings you can tweak:
    RCUT - Red Cutoff
    GCUT - Green Cutoff
    BCUT - Blue Cutoff
    GDRV - Green Drive
    BDRV - Blue Drive
    BRTC - Brightness Centre
    SCNT - Subcontrast
    COLP - Colour (PAL?)
    COLS - Colour (SECAM?)
    SBY - May be something to do with conversion between Blue and Luma
    SRY - May be something to do with conversion between Red and Luma
    HPOS - Horizontal Position
    HIT - Height
    VLIN - Vertical Linearity
    WID - Width
    PARA - Parabola (i.e. Pin Cushion)
    CNR - Corner PARA (better pincushion control at 4 corners)
    TRAP - Trapeziod
    CPAR - Centre PARA (better pincushion control at 4 corners)
    HSC - Horizontal S-Correction (?)
    VPS1 - Vertical Phase Shift (?)
    CSAW - Centre SAW
    OPT3 - I wouldn't touch things like this!
    I have now managed to set the picture up a heck of a lot better. But be aware that getting one mode (widescreen for example) spot on often screws up some of the other modes. Be prepared to make a compromise to get all modes looking good if you have similar issues as mine. Also try to make a note of the original settings in the service menu, as it is very easy to screw things up.
    2.
    Toshiba 36ZP38 Original Service Mode settings (IN RED ARE MY CHANGES)
    WIDE MODE (same settings used for 14:9 and 4:3)
    Parameter Factory Function New setting
    GCUT 3AH Green cut off
    RCUT 40H Red cut off
    OPT3 01H ?
    CSAW 07H Vertical saw-tooth 05H
    VPS1 76H Vertical position (fine) 7AH
    HSC 11H Vertical curvature 0FH
    CPAR 06H Centre Par 07H
    TRAP 42H Trapezium 4DH
    CNR 13H Corner geometry
    PARA 15H Parabola / Pincushion 14H
    WID 28H Width (all modes) 29H
    VPS2 3EH Vertical position (coarse)
    VLIN 11H Vertical linearity
    HIT 2BH Height (all modes) 29H
    HPOS 32H Horizontal position 33H
    SRY 07H Secam Black level R-Y axis
    SBY 04H Secam Black level B-Y axis
    COLS 19H Secam colour level
    COLP 15H Sub Colour
    SCNT 1FH Sub Contrast
    BRTC 8EH Sub Brightness
    BDRV 22H Blue Drive
    GDRV 31H Green Drive
    BCUT 7EH Blue cut off
    SUPER LIVE
    OPT3 01H ?
    CSAW 05H Vertical saw-tooth
    VPS1 79H Vertical position (fine) 7AH
    HSC 0EH Vertical curvature 0FH
    CPAR 08H Centre Par
    TRAP 47H Trapezium 4CH
    CNR 18H Corner geometry
    PARA 19H Parabola / Pincushion
    WID 31H Width (all modes)
    VLIN 0EH Vertical linearity
    HIT 2EH Height (all modes)
    HPOS 33H Horizontal position
    COLP 15H Sub Colour
    BDRV 22H Blue Drive
    CINEMA
    OPT3 01H ?
    VPS1 7BH Vertical position (fine)
    HSC 0FH Vertical curvature
    CPAR 06H Centre Par
    TRAP 4EH Trapezium
    CNR 1AH Corner geometry
    PARA 25H Parabola / Pincushion
    VLIN 0FH Vertical linearity
    HIT 44H Height (all modes)
    HPOS 34H Horizontal position
    COLP 15H Sub Colour
    BDRV 22H Blue Drive
    Hope it helps yer.
  3. Free To Air
    Free To Air Member
    Mar 22, 2004
    934
    28
    +27
    Loopy,
    Many thanks, that is exactly what I was looking for.
    Could you please clear up one point re your reply? Have I read it correctly that there is an inbuilt test card in the TV that is obtained by pressing the SOURCE INPUT whilst in "Service Menu" mode? Or, is that referring to the fact that if I have the Video Essentials DVD in my DVD player it will cycle to the test card from the Video Essentials DVD.
    I will have a tinker and see if I can alter the geometry to what I need.
    Regards
    moonbase
  4. dicy
    dicy Member
    Jun 18, 2003
    25
    Loopy
    Could you post again please mate, i can't see the red changes.
    RICH:lease:
  5. L00py^
    L00py^ Member
    Sep 23, 2004
    129
    These are other peoples changes my tv was fine.
    For example
    RCUT 40H Red cut off - NO CHANGE
    OPT3 01H ? - NO CHANGE
    CSAW 07H Vertical saw-tooth 05H - CHANGED SETTING FROM 07H to 05H.
