A .wav or .flac player for hi-fi system
Discussion in 'Hi Fi Systems & Separates' started by Paradox2701, Oct 31, 2011.
  1. Paradox2701
    Paradox2701 Member
    Oct 31, 2011
    4
    Dear all,
    Currently my hifi setup comprises a basic pioneer dvd player attached to a supernait and a pair of maggie 1.7s. I mainly listen to classical music. I would like to play .flac and .wav files that are not supported by the dvd player. I have been wondering if anyone have listened to the Naim NDX or HDX and compared with Logitech Squeezebox. Are there any other recommendations? The price of the NDX and HDX will get my wife to kill me...but would using the squeezebox be non-hifi? Any opinions? Thanks!
  2. formbypc
    formbypc Member
    Oct 9, 2010
    1,577
    63
    +103
    I'm very happy with the performance of the SB Touch.
    Wouldn't describe it as 'Non HiFi' at all, and I've been listening to HiFi since the mid-1970s. The quality of your source files will have more of an impact than the sound of the SB.
    In order to play your FLAC or WAV files, you'll need them in one of the following places;
    On a USB drive that you attach directly to the SB
    On a Network-access Storage medium (NAS) within your home network
    In a folder shared on your network
    You can access your network wirelessly or through ethernet cable, whichever is convenient for you.
    • Thanks Thanks x 1
  3. amcluesent
    amcluesent Moderator
    Aug 13, 2002
    4,795
    +891
    Naim have announced the ND5 XS streamer at a lower price point than the NDX - about £2K. The Linn Majik DS would also be on my list to audition.
    Many of the streamers still have problems with gapless playback, which is show-stopper for classical music.
    Streamer forum - http://www.avforums.com/forums/streamers-network-music-players/
    • Thanks Thanks x 1
  4. krazyolie
    krazyolie Member
    Apr 26, 2010
    56
    +3
    SB touch either with internal or external DAC?
    OR a bog standard laptop with a USB DAC?
  5. Don Dadda
    Don Dadda Active Member
    Sep 20, 2007
    4,200
    +477
    No less than using the DVD player. Call it New Age Hi Fi if you like.
    It plays or should i say streams music in the most or all of the best formats that digitized music can be heard in. Can be as good as a cd or vinyl, provided that the recording which it was ripped from is of good SQ . It also plays crap too - again recording dependant or ripped to low bit rated compressed mp3 files.
    I do not have a touch but the SB3 Classic V3. while it does not have the functionality of the Touch, it plays the same formats as the touch (i think) and music is a delight to listen to.
    For the price of it, i would expect the Naim to be much better.
    • Thanks Thanks x 1
  6. krazyolie
    krazyolie Member
    Apr 26, 2010
    56
    +3
    The touch with a good DAC will probably outclass a similarly priced CD player. Pretty much all the touch would be doing is decoding the flac files, then the DAC does all the hifi business. Supposedly the internal one is not half bad though.
  7. Paradox2701
    Paradox2701 Member
    Oct 31, 2011
    4
    ok..so can i say that if i want to get a hifi sound touch has to be added with an outboard DAC? and if that is the case the outlay of cash is the same as a naim hdx or ndx?
  8. TopMeTom
    TopMeTom New Member
    Sep 8, 2002
    8,242
    +270
    I would say no the cash outlay would be a lot less. You could pickup a touch for £160ish and even a rdac £250ish second hand.
    So 4-500 ish is nowhere near a ndx?
  9. Paradox2701
    Paradox2701 Member
    Oct 31, 2011
    4
    Heh I guess...but just another thing. Don't the Supernait comes in with an onboard DAC? Is tt sufficient for the squeezebox? or is an outboard DAC necessary? I guess if that is the case I can alway look at this as an upgrade option? Get the squeezebox first..and when I think I need a better sound/have money to spend then get the rDAC?
  10. krazyolie
    krazyolie Member
    Apr 26, 2010
    56
    +3
    Sounds sensible, there are also "upgraded"/modified squeezebox touch units available, New Squeezebox Touch with level 1 upgrade and PSU ... could be nonsense though!
    • Thanks Thanks x 1
  11. formbypc
    formbypc Member
    Oct 9, 2010
    1,577
    63
    +103
    It sounds perfectly acceptable without an extra DAC, but if you want to go the extra mile.....
