5.1 sound with Handbrake
gerbilly
Joined
Mar 20, 2005
Messages
2,202
Reaction score
102
Points
523
Age
56
Location
Hamilton
I have copied a few of my movies to enable me to watch them on Apple TV.
I have went to the audio settings and I have set them at 5.1, however there is a section called mixdown with the following options
Mono
stereo
dolby surround
Pro logic II
6 Channel discrete
do I have to select one of these to get 5.1 sound?
Any help would be appreciated before I copy anymore in preparation for moving my i tunes folder.
I have now up dated the presets to se if that helps.
Hi, :hiya:
what you will need to do it is have the first audio track set to:
AAC > Dolby Pro Logic 2 > Auto > 160 kbps
then in the 2nd audio track under "Audio Codec" select the AC3 and that's it.
Are you using version 0.93? there is a good AppleTV preset in there which very well. I use a slightly different config with 59% Constant Quality and it looks great, with pretty good files sizes. I only wish I hadn’t done 400 of my DVD's with Avg Bitrate of 2500 when I first got in to this lol, I'm half way thru re-doing them all now with 59%
have fun :D
Hi, :hiya:
Are you using version 0.93? there is a good AppleTV preset in there which very well. I use a slightly different config with 59% Constant Quality and it looks great, with pretty good files sizes. I only wish I hadn't done 400 of my DVD's with Avg Bitrate of 2500 when I first got in to this lol, I'm half way thru re-doing them all now with 59%
have fun :D
Right now I am copying Sideways
audio choices are
Track 1
SOURCE - English (AC3) (5.1 CH)
AUDIO CODEC - AAC (FAAC) or (AC3 Passthru)
MIXDOWN - As discussed in first post
SAMPLERATE - Set at Auto
BITRATE - Set at 128
what is the best setting and do I have to enter something for track 2?, is that correct?
In Video what is the best bitrate to set?
I just use 'universal' which I think keeps the 5.1 as a second audio track. If you aren't happy with the quality (I am), then bump it up a little higher.
Many people on handbrake and other forums who have carefully created, manually tweaked profiles have switched to 'universal' since 0.93
The only thing they tend to tweak is adding 'decomb' if its an animated feature
I would put the first track as AAC and the second track as AC3.
Some people have problems if they are in the other order IE AC3 first then AAC.
Been using these settings for all my apple tv rips and I get 5.1 on every rip.
thanks just going to use that setting now, anyone answer what the bitrate should be on the video settings?
I cant figure this out. I dont get AC3 passthru on second option...HELP I have realised this applies only to macs anything for windows
Is 4K Blu-ray Worth It?
Back
