4 gang wall sockets - do they exist?
Discussion in 'Home Cinema Building DIY' started by Vorix, Dec 24, 2007.
  1. Vorix
    Vorix Member
    Feb 2, 2005
    337
    +10
    I've been searching the web to no avail.
    Is it possible to get a 4 gang switched wall socket to replace a current 2 gang one? I've found a triple but thought that I may as well go to 4 if they are available.
    I want to use a couple of Homeplugs but am aware that they don't recommend using them with trailing sockets. If I dedicate 1 socket to the plug then that means having everything else hanging off the one remaining socket!
  2. ukbootlegs
    ukbootlegs Active Member
    Feb 7, 2006
    3,816
    +320
  3. gillw
    gillw Member
    Jul 11, 2003
    116
    +6
    Is it ok to shorten the cable on a 4 gang trailing socket or do they have to have a fixed amount of cable on them?
    The one I have has about a metre of cabling on it and I would like to shorten it a bit to make things look a bit neater?
  4. Vorix
    Vorix Member
    Feb 2, 2005
    337
    +10
  5. ukbootlegs
    Feb 7, 2006
    3,816
    +320
    couldnt tell yer m8
    i saw your post and thought if anyone sells them then screwfix does and took a gander on your behalf
  6. Beaker
    Beaker Member
    May 4, 2002
    96
    11
    +7
    Gillw, you can shorten the flex if you know how to rewire a plug, or in side the 4way block. There is no limit on shortness. It is more to do with coiling wire up like in a cable reel.
    Beaker
    • Thanks Thanks x 1
  7. lowmans100
    lowmans100 Member
    Dec 20, 2006
    1,058
    63
    +204
    Have you considered just putting another 2 gang next to your existing 2 gang
  8. gasspark
    gasspark Guest
    Plugs straight on to existing single or twin socket
  9. gasspark
    gasspark Guest
    This is all true but if you have the knowledge wire the block keeping the moulded plug, this is for the safety of others.
  10. gillw
    gillw Member
    Jul 11, 2003
    116
    +6
    Thank You.
    Merry Christmas to you all.:)
  11. Vorix
    Vorix Member
    Feb 2, 2005
    337
    +10
    Bought a 4 gang and a 3 gang block from Screwfix and just wired them in to the existing 2 gang box in the wall. They are cleverly designed so that the screw holes match. One thing to note is that they sit quite a lot more proud of the wall than the old socket.
    I also bought the Homeplugs and these are working perfectly in the new sockets.
    Thanks to all for your help.
  12. the_watcher87
    the_watcher87 Member
    Jan 3, 2008
    708
    +57
    great, i didnt know these existed either. In my new house theres only one outlet in the three bedrooms so these will be ideal for me
    thanks!!!
