24 fps from blu-ray discs
Discussion in 'Blu-ray & DVD Players' started by jonoc, Jun 25, 2008.
  1. jonoc
    jonoc Member
    Mar 25, 2006
    83
    +13
    Do all pre-recorded blu-ray discs output 24 fps.
    If not, how do you know which do and which don't.
    Also, if you play a SD DVD on a blu-ray player which is set to 24 fps output will the panel display the picture correctly.
  2. kingfats
    kingfats Well-Known Member
    Dec 29, 2006
    36,484
    +7,844
    Hi jonoc. :)
    Nearly all are 1080p/24,there's few music BD's @1080i/60 (video) though.
    SD DVD on a PAL BD player will be @ 50Hz,as per normal :smashin: NTSC will be @ 60Hz,.
    The BD50 (NTSC) can play film DVD @ it's original framerate.......24fps.
    EDIT: Most playes auto-switch framerate when you play a DVD,if already set to 24p.
    Cheers.
    • Thanks Thanks x 1
