2nd Hand 360 Live
Old 11-06-2007, 6:59 PM   #1
15,046, Level: 29
Points: 15,046, Level: 29 Points: 15,046, Level: 29 Points: 15,046, Level: 29
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 288, Got 545
2nd Hand 360 Live
thinking of buying an Xbox 360 second hand.
It has 6 months Xbox live left on it. If I buy the Xbox will I have trouble using another persons account. How does it work? & will I need the sellers codes/passwords?
Old 11-06-2007, 7:37 PM   #2
10,747, Level: 24
Points: 10,747, Level: 24 Points: 10,747, Level: 24 Points: 10,747, Level: 24
Thanks: Gave 93, Got 533
Re: 2nd Hand 360 Live
You'll need his Live email address & password to be able to login using his Xbox live account - I doubt he would give you this.
If you bought a premium you'd get 1 month xbox live gold trial, but would need a subscription / prepaid card after that.
Unless the Xbox is <£100 w. all accessories then don't bother, it really is worth having a full warranty with a 360 (sad but true).
Old 11-06-2007, 7:39 PM   #3
5,033, Level: 16
Points: 5,033, Level: 16 Points: 5,033, Level: 16 Points: 5,033, Level: 16
Thanks: Gave 3, Got 154
I wouldn't buy an Xbox second hand because of the 3reds issues.
I REALLY wouldn't buy one since a load of Xboxes got banned from Live. Where do you think they will all end up?
eBay etc
Old 11-06-2007, 7:45 PM   #4
15,046, Level: 29
Activity: 2.7%
cheers, thanks for swift response. The bidding ends in 10 mins - I won't be taking part.
Thanks again
