| NAT Settings Issue
Hi guys - i appreciate you must get these all the time however on this one i'm truly stumped, even after a fair bit of research!
Basically upon getting Modern Warfare 2 I saw when going into play multiplayer online it registered my NAT settings as 'moderate', and sometimes even 'strict'. Now the Xbox itself never told me there was any problems when connecting to Xbox live, or testing the connection - however it does make sense as i do quite regularly have problems in joining peoples party's / games.
My network info:
I have a Netgear DG834GT router, and can connect to it either by wireless or cable. The router is being used as a DHCP Server, and initially i assigned my Xbox a specific IP address within the range.
When forwarding the ports i made sure i forwarded them all specifically to this pre-assigned IP address for my Xbox 360 - this didn't work at all.
I also have tried making sure UPnP is enabled - which it is.
I have also tried using my Xbox's assigned IP address as a DMZ - again no luck.
The thing that really baffles me though is that my brother is connected to the exact same network, with no assigned IP, no ports forwarded and his NAT settings appear as open!?!
(I have also tried de-assigning my Xbox it's IP - so it changes each time like my brothers - this doesn't work either)
Now i'm stuck, nothing seems to work - i can't even get any consistency keeping it at moderate - it fluctuates as it wishes!
Where i have assigned my Xbox an IP in the DHCP range - is that the same as manually assigning (in Xbox's dashboard) an IP address?
Any help guys would be much appreciated!
