xbox live disconnecting
Old 07-11-2009, 4:25 AM   #1
Thanks: Gave 27, Got 2
has any one else had there console disconnect from live wen in a game and then wont reconnect but wen you go back to dash it reconnects its happend to me 2 times tonite on gears 2 and once on halo ODST a few weeks ago
Old 07-11-2009, 8:16 AM   #2
1,472, Level: 8
Points: 1,472, Level: 8 Points: 1,472, Level: 8 Points: 1,472, Level: 8
Thanks: Gave 27, Got 32
Re: xbox live disconnecting
Happens quite a lot to us, I have to reboot (turn power off and back on) the router then it seems to fix it for a while. I think I might just need a new router as it is not handling the amount of data quick enough from the various connections in the house.
Old 07-11-2009, 9:17 AM   #3
3,962, Level: 14
Points: 3,962, Level: 14 Points: 3,962, Level: 14 Points: 3,962, Level: 14
Thanks: Gave 2, Got 105
it's been happening on Forza 3, your logged in & playing then you get a message to say you've disconnected & the only way back on is to exit the game where you automatically rejoin
