Connecting to live???
Old 29-10-2009, 12:52 PM   #1
Hi there,
I want to connect my xbox to live....
My xbox is upstairs and my router is downstairs, so I was looking at a wireless adapter... The proper xbox one was like £50 which I cant afford atm, Can you use normal ones for your PC which are cheaper??
Or if anyone can suggest anyother suggestions???
Thanks James
Old 29-10-2009, 1:43 PM   #2
King Tones's Avatar
41,464, Level: 49
Points: 41,464, Level: 49 Points: 41,464, Level: 49 Points: 41,464, Level: 49
Activity: 29.2%
Activity: 29.2% Activity: 29.2% Activity: 29.2%
Thanks: Gave 3,304, Got 3,512
Re: Connecting to live???
Originally Posted by iomjames View Post
Hi there,
Thanks James
PC Ones wont work.
You can pick them up off here in the classifieds for about £30
Or check Amazon Marketplace sometimes £35.
Or you could look into Homeplugs but i am not sure on those.
Deftones
