AVF Battlefield 1943 Group
Old 09-07-2009, 1:10 PM   #1
DpM DpM is online now
10,531, Level: 24
Points: 10,531, Level: 24 Points: 10,531, Level: 24 Points: 10,531, Level: 24
Activity: 14.5%
Activity: 14.5% Activity: 14.5% Activity: 14.5%
Thanks: Gave 513, Got 347
As with the other AVF Group profiles, just created a new profile for regular players of
Battlefield 1943
Thought id set up a 1943 group as it would be handy to fill those private 16 player matches, just send a friend request to AVF 1943 with a message along the lines of "from the forums" so I know you're from here.
I'll sign in regularly to check and accept friends requests, then of course just use the friends of friend feature(check the friends list for the AVF 1943 profile) to send/receive invites, join session in progress etc.
If you later decide the game isn't for you, please remove this tag from your friends list as the 100 spaces will likely fill up fast & you're space could be appreciated by somebody else.
Look forward to seeing killing you all on-line.
*thanks to Tetlee, i ripped off most of his text from another post
Anotherlimey (09-07-2009), BlackCammeh (09-07-2009), Mr Noble (09-07-2009), RCD01 (09-07-2009), SourKraut (09-07-2009), Spidey987 (09-07-2009)
Old 09-07-2009, 2:24 PM   #2
1,283, Level: 8
Points: 1,283, Level: 8 Points: 1,283, Level: 8 Points: 1,283, Level: 8
Thanks: Gave 29, Got 6
Re: AVF Battlefield 1943 Group
are you puting a members list on this thred? because im joining this lol
Old 09-07-2009, 2:31 PM   #3
10,531, Level: 24
Activity: 14.5%
Accepted
Don't think we need a list, its easy enough to check form your 360.
Unless general consensus is we need one.
Old 09-07-2009, 2:40 PM   #4
5,680, Level: 17
Points: 5,680, Level: 17 Points: 5,680, Level: 17 Points: 5,680, Level: 17
Activity: 7.1%
Activity: 7.1% Activity: 7.1% Activity: 7.1%
Thanks: Gave 320, Got 233
cheers for setting this up. I have sent a FR.
Old 09-07-2009, 2:48 PM   #5
12,514, Level: 26
Points: 12,514, Level: 26 Points: 12,514, Level: 26 Points: 12,514, Level: 26
Activity: 23.6%
Activity: 23.6% Activity: 23.6% Activity: 23.6%
Thanks: Gave 378, Got 993
Sent a FR
Old 09-07-2009, 2:54 PM   #6
10,531, Level: 24
Activity: 14.5%
Accepted both of you
Old 09-07-2009, 3:35 PM   #7
15,960, Level: 30
Points: 15,960, Level: 30 Points: 15,960, Level: 30 Points: 15,960, Level: 30
Thanks: Gave 442, Got 809
Sent FR.
Old 09-07-2009, 3:45 PM   #8
14,696, Level: 29
Points: 14,696, Level: 29 Points: 14,696, Level: 29 Points: 14,696, Level: 29
Activity: 22.3%
Activity: 22.3% Activity: 22.3% Activity: 22.3%
Thanks: Gave 293, Got 388
Sent a request, Thanks for setting it up
Old 09-07-2009, 3:55 PM   #9
10,531, Level: 24
Activity: 14.5%
For some odd reason it says I can't accept your request, the user does not exist.
Can you send another and ill try again.
Old 09-07-2009, 3:57 PM   #10
50,196, Level: 54
Points: 50,196, Level: 54 Points: 50,196, Level: 54 Points: 50,196, Level: 54
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,070, Got 2,048
Cheers for setting it up - I'll pop an invite in a sec.
I've added it to the sticky list at the top of the forum too (link in my sig).
DpM (09-07-2009)
Old 09-07-2009, 3:57 PM   #11
10,531, Level: 24
Activity: 14.5%
Originally Posted by reddevil63 View Post
Sent FR.
Accepted
Old 09-07-2009, 4:03 PM   #12
6,457, Level: 19
Points: 6,457, Level: 19 Points: 6,457, Level: 19 Points: 6,457, Level: 19
Thanks: Gave 196, Got 33
Hi DPM
I've sent you a request but forgot to mention anything about the forums............sorry!
My tag is SCARBUM007
Old 09-07-2009, 4:08 PM   #13
10,531, Level: 24
Activity: 14.5%
Originally Posted by sarll View Post
Hi DPM
No probs, all sorted.
Old 09-07-2009, 4:10 PM   #14
10,531, Level: 24
Activity: 14.5%
Cheers Munkey Boy.
Old 09-07-2009, 4:25 PM   #15
mossym's Avatar
Location: You'd get your feet wet getting here, but the Guinness is worth it...
24,851, Level: 38
Points: 24,851, Level: 38 Points: 24,851, Level: 38 Points: 24,851, Level: 38
Activity: 11.8%
Activity: 11.8% Activity: 11.8% Activity: 11.8%
Thanks: Gave 598, Got 1,310
just sent a request, but did it online so wasn't able to add a message, but if it gets rejected will send another from my xbox when i get home
Old 09-07-2009, 4:41 PM   #16
8,709, Level: 22
Points: 8,709, Level: 22 Points: 8,709, Level: 22 Points: 8,709, Level: 22
Thanks: Gave 368, Got 107
sent request
Old 09-07-2009, 4:42 PM   #17
Thanks: Gave 1,761, Got 1,379
Just sent of a FR and a message as i did on the laptop , Gamertag Gateshead Mob
See you on the battlefield
Old 09-07-2009, 5:49 PM   #18
9,943, Level: 23
Points: 9,943, Level: 23 Points: 9,943, Level: 23 Points: 9,943, Level: 23
Thanks: Gave 127, Got 99
request sent xbox name "kidderbean"
Old 09-07-2009, 6:13 PM   #19
10,531, Level: 24
Activity: 14.5%
All requests accepted, were up to 30 now
Anotherlimey UK yours has now gone through OK
Old 09-07-2009, 7:52 PM   #20
14,696, Level: 29
Activity: 22.3%
Will do, Changed my gamertag slighty since, That must be the reason.
Old 09-07-2009, 8:43 PM   #21
Conspicuous Member
31,801, Level: 43
Points: 31,801, Level: 43 Points: 31,801, Level: 43 Points: 31,801, Level: 43
Activity: 9.8%
Activity: 9.8% Activity: 9.8% Activity: 9.8%
Thanks: Gave 114, Got 428
I am about to send out a request to the group gamertag.
Old 10-07-2009, 6:59 AM   #22
7,650, Level: 20
Points: 7,650, Level: 20 Points: 7,650, Level: 20 Points: 7,650, Level: 20
Thanks: Gave 99, Got 76
FR sent also, from online, so no message as mentioned
soo.. assuming accepted, what happens then?
Old 10-07-2009, 7:10 AM   #23
10,531, Level: 24
Activity: 14.5%
You can then view the friends of the tag via the guide button when in game and see who is playing to join them. You can also then set up your own games and invite people from it, they will also be able to invite you.
Ill pop on and accept it now.
Old 10-07-2009, 7:16 AM   #24
10,531, Level: 24
Activity: 14.5%
The tag is up to 39 friends
Ill check again at lunchtime.
Old 10-07-2009, 8:42 AM   #25
1,423, Level: 8
Points: 1,423, Level: 8 Points: 1,423, Level: 8 Points: 1,423, Level: 8
Thanks: Gave 81, Got 46
I forgot to add any text to let you know I was from the forums - SORRY
Old 10-07-2009, 11:24 AM   #26
10,531, Level: 24
Activity: 14.5%
Accepted some more FR's were up to 43 on the list now
Old 10-07-2009, 12:12 PM   #27
4,544, Level: 15
Points: 4,544, Level: 15 Points: 4,544, Level: 15 Points: 4,544, Level: 15
Thanks: Gave 92, Got 283
Hey DpM.
I just wanted to let you know, i just sent a FR to the AVF 1943 tag, but stupidly, forgot to add a message saying i was from AVF. Muppet sometimes me
So yeah, gamertag is FerretBueller, so if you see the request from me, please accept as i am from here
Look forward to a game with you all this eve, assuming i can get passed the free mini game which seems to involve sitting on the 'searching for game' screen
From what i have played so far, game seems great
Old 10-07-2009, 12:22 PM   #28
10,531, Level: 24
Activity: 14.5%
Originally Posted by Norlo View Post
Hey DpM.
Accepted you
Norlo (10-07-2009)
Old 10-07-2009, 12:27 PM   #29
7,650, Level: 20
Cheers Mr McDaniels
Old 10-07-2009, 12:36 PM   #30
10,531, Level: 24
Activity: 14.5%
Cheers Mr McDaniels
Yor welcome
