Originally Posted by gruber [I]
Thanks! Tried the Win AVI fee download. As you said, very fast and looks gr8 on my TV. Is this the best programme to go for in your opinion? I presume that you have to pay for this type of software.
I really appreciate your post.  |
For speed its the best without a doubt mate
but for quality you do lose a little bit of quality from your encodings and its very hard to control the quality settings with winavi (i.e exact bitrate of the file)
and yes winavi does cost money
but the 2 programs which i think do a better job are completely free
Super and avidemux
sadly these programs are very very slow at converting compared to winavi
my advice to you would be..
If you wanted to encode mostly HD quality files then stick with something like Super or avidemux but if most of your files are standard dvd quality then using winavi is fine
p.s when converting to avi (using winavi) im losing 5.1 - not sure why - looking into the problem - winavi keeps using mp3 audio for some reason when i want ac3
