frozen check screen, no red lights
Old 19-08-2007, 6:17 PM   #1
1,637, Level: 9
Points: 1,637, Level: 9 Points: 1,637, Level: 9 Points: 1,637, Level: 9
Hi there,
my 360 just died ! I think every time i put a game in ,my screen freezes with small squares all over the screen. Iv looked over the net and iv only found "frozen screen" everywhere none have the squares though. Also no red rings
any ideas anybody
Old 19-08-2007, 6:29 PM   #2
25,685, Level: 39
Points: 25,685, Level: 39 Points: 25,685, Level: 39 Points: 25,685, Level: 39
Activity: 16.3%
Activity: 16.3% Activity: 16.3% Activity: 16.3%
Thanks: Gave 432, Got 828
Re: frozen check screen, no red lights
360 has gone m8 had it twice take it back where ever you got it or send it back to M$..
Old 19-08-2007, 7:33 PM   #3
6,166, Level: 18
Points: 6,166, Level: 18 Points: 6,166, Level: 18 Points: 6,166, Level: 18
Thanks: Gave 85, Got 42
I believe it's a common problem. My first one started doing the same thing not long before it went totally nipples up (three red lights)!
Old 19-08-2007, 8:27 PM   #4
11,124, Level: 25
Points: 11,124, Level: 25 Points: 11,124, Level: 25 Points: 11,124, Level: 25
Thanks: Gave 175, Got 145
mine did that a few times, turn it off to cool down and would work for 2-3 mins then checkerboard. Wasnt long , ROD came!
HTML code is On
