XBOX 360 Elite & Sayno Z3
Old 19-08-2007, 5:11 PM   #1
5,126, Level: 16
Points: 5,126, Level: 16 Points: 5,126, Level: 16 Points: 5,126, Level: 16
Thanks: Gave 1, Got 0
Hi All,
I already own an XBOX 360 with this projector but have ordered the Elite to use HDMI on my projector.
Will the HDMI mode make the picture any clearer on this projector? I think it can only reach 1080i.
Look forward to your replies.
Regards
Richard
Old 19-08-2007, 5:29 PM   #2
44,497, Level: 51
Points: 44,497, Level: 51 Points: 44,497, Level: 51 Points: 44,497, Level: 51
Thanks: Gave 108, Got 1,460
Re: XBOX 360 Elite & Sayno Z3
Originally Posted by rmculver View Post
Hi All,
Regards
Richard
It's not going to make a significant difference unless your display supports 1080p. Personally I think HDMI does look better then VGA or component on my TV even at 720p and 1080i. I certainly wouldn't buy an Elite if I already have a working 360 just for the HDMI connection at least as it's not siginificant enough to justify it. I guess if you prefer the black colour and want the bigger hard drive it may be worth it.
HTML code is On
