VGA Cable
Old 18-08-2007, 9:52 PM   #1
Mimplings
Posts: n/a
VGA Cable
is there any way i can get it to work on my laptop?
it has a VGA port on the back but there must be a way to switch from the laptop view to the 360?
cheers
Old 18-08-2007, 9:56 PM   #2
Illustrious Member
BenchyUK's Avatar
47,248, Level: 53
Points: 47,248, Level: 53 Points: 47,248, Level: 53 Points: 47,248, Level: 53
Activity: 47.3%
Activity: 47.3% Activity: 47.3% Activity: 47.3%
Thanks: Gave 395, Got 933
Re: VGA Cable
I think VGA sockets on laptops are only there for outputing to a larger screen, although i may be wrong
Old 18-08-2007, 10:26 PM   #3
44,497, Level: 51
Points: 44,497, Level: 51 Points: 44,497, Level: 51 Points: 44,497, Level: 51
Thanks: Gave 108, Got 1,460
Re: VGA Cable
That is correct. Laptop VGA connections are for output only to an external display.
Old 18-08-2007, 10:49 PM   #4
Mimplings
Posts: n/a
Re: VGA Cable
ok thanks,
back it goes, also in the fs section
HTML code is On
