cannot connect VGA cable .....
Old 18-08-2007, 6:10 PM   #1
geforce91
Posts: n/a
hi i recently purchased a bush hd lcd tv and am trying to connect my xbox 360 to it....
the standard hd av cables work fine but i am trying to get it connected via a hd VGA cable i have.
firstly i have tried connecting the vga cables and xbox to another lcd tv i have and have been successful.
however on this tv i have connected the cables but i only get 'no signal' even though i have selected VGA as the source.....
do you think this could be a faulty connection or somthing else?
thank you for your help
Old 18-08-2007, 10:19 PM   #2
44,497, Level: 51
Points: 44,497, Level: 51 Points: 44,497, Level: 51 Points: 44,497, Level: 51
Thanks: Gave 108, Got 1,460
Re: cannot connect VGA cable .....
It could be that whatever resolution the 360 was set to when connected to the other TV is not supported by the Bush TV. It might be owrth trying to connect to the other TV again and changing the resolution to whatever is native on the Bush TV. That might work.
HTML code is On
