Can this work with 360?
Old 17-08-2007, 3:22 PM   #1
6,502, Level: 19
Points: 6,502, Level: 19 Points: 6,502, Level: 19 Points: 6,502, Level: 19
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 133, Got 31
http://www.game.co.uk/ViewProduct.as...180&mid=327565
Will the live subscription work with 360?
Old 17-08-2007, 3:26 PM   #2
12,909, Level: 27
Points: 12,909, Level: 27 Points: 12,909, Level: 27 Points: 12,909, Level: 27
Thanks: Gave 548, Got 507
Re: Can this work with 360?
It is listed as out of stock... and there will be no new stock...
Old 17-08-2007, 3:38 PM   #3
6,502, Level: 19
Activity: 4.2%
yeah i know, but can it work though?
Old 17-08-2007, 5:03 PM   #4
6,909, Level: 19
Points: 6,909, Level: 19 Points: 6,909, Level: 19 Points: 6,909, Level: 19
Thanks: Gave 87, Got 152
afaik, yes. It works. It basically gives you the xbox live subscription, which I think ms will upgrade to 360 live... So a bargain if you can get some
(get me one of them while you're at it pls )
Old 17-08-2007, 5:56 PM   #5
44,497, Level: 51
Points: 44,497, Level: 51 Points: 44,497, Level: 51 Points: 44,497, Level: 51
Thanks: Gave 108, Got 1,460
Yes it would work but I very much doubt they will have anymore.
Old 18-08-2007, 8:34 AM   #6
12,052, Level: 26
Points: 12,052, Level: 26 Points: 12,052, Level: 26 Points: 12,052, Level: 26
Thanks: Gave 383, Got 129
I have used 2 of these packs so far on my 360 - PES5 when I first got the console and a PGR2 one a year later (game still in is sealed pack - never opened!).
Very rare to see them available anymore.
Is LIVE to popular now for MS to do something similar for 360 games? Best we get now is a 48 hour trial card.
Old 18-08-2007, 10:29 AM   #7
28,238, Level: 40
Points: 28,238, Level: 40 Points: 28,238, Level: 40 Points: 28,238, Level: 40
Thanks: Gave 14, Got 999
There are over 7 million Xbox Live users, thats more than Xbox 1 ever had, of course LIVE is popular and they do pack live subscription codes in with games, also with the camera.
Old 18-08-2007, 10:34 AM   #8
12,052, Level: 26
I had only seen 48 hr / 1 month cards with games so far on 360 - nothing like the 'almost' free 12 months you could get with Xbox ones.
If there are some - I'd be keen to get one, as Live sub is up in 2 months (5 if my compenstation card from MS arrives).
Seen the camera one - but I don't want it.
Cheers for reply.
HTML code is On
