where does Optical Cable plug into the 360?
Old 17-08-2007, 2:57 PM   #1
14,672, Level: 29
Points: 14,672, Level: 29 Points: 14,672, Level: 29 Points: 14,672, Level: 29
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 415, Got 47
Question where does Optical Cable plug into the 360?
hi,
Thinking about buying an Optical Cable for the 360-where about on the 360 does it plug into?
http://www.amazon.co.uk/Mad-Catz-MOV...362521&sr=1-22
Old 17-08-2007, 3:02 PM   #2
kav kav is offline
31,145, Level: 43
Points: 31,145, Level: 43 Points: 31,145, Level: 43 Points: 31,145, Level: 43
Activity: 31.8%
Activity: 31.8% Activity: 31.8% Activity: 31.8%
Thanks: Gave 3,609, Got 4,974
Re: where does Optical Cable plug into the 360?
Into the back of the cable going to the tv.
Edit to clarify: Right where the cable plugs into the console.
Old 17-08-2007, 3:14 PM   #3
14,672, Level: 29
Activity: 1.0%
hi,
thanks for the reply. What cable? the power cable or the a/v
Old 17-08-2007, 3:16 PM   #4
6,367, Level: 19
Points: 6,367, Level: 19 Points: 6,367, Level: 19 Points: 6,367, Level: 19
Thanks: Gave 371, Got 119
Originally Posted by Ewan154 View Post
hi,
AV
Ewan154 (17-08-2007)
Old 17-08-2007, 3:17 PM   #5
5,837, Level: 18
Points: 5,837, Level: 18 Points: 5,837, Level: 18 Points: 5,837, Level: 18
Thanks: Gave 32, Got 121
its the av cable but only if you have the component or vga version. with the standard composite cable that comes with the core version you dont get the optical jack!
Old 17-08-2007, 3:19 PM   #6
kav kav is offline
31,145, Level: 43
Activity: 31.8%
That sucks.
Old 17-08-2007, 3:28 PM   #7
14,672, Level: 29
Activity: 1.0%
I have th core version
Old 17-08-2007, 3:30 PM   #8
2,146, Level: 10
Points: 2,146, Level: 10 Points: 2,146, Level: 10 Points: 2,146, Level: 10
Thanks: Gave 40, Got 42
Advanced scart lead has the Optical Jack also.
Old 17-08-2007, 3:55 PM   #9
5,837, Level: 18
well yes i guess but if you care about how it looks at the very least you need the rgb scart cable or if you have a hd screen then you need the component or vga cable!!!!
Old 17-08-2007, 4:24 PM   #10
solidamber's Avatar
3,782, Level: 14
Points: 3,782, Level: 14 Points: 3,782, Level: 14 Points: 3,782, Level: 14
Thanks: Gave 44, Got 116
Argos are doing an Avanced lead for under a fiver. I have this lead and can report it has an optical port and is well made.
or the RGB scart version at only £2.99
http://www.argos.co.uk/webapp/wcs/st...o.x=13&go.y=15
http://www.argos.co.uk/webapp/wcs/st...chTerms=360+av
Old 18-08-2007, 9:44 AM   #11
D@Z D@Z is offline
7,948, Level: 21
Points: 7,948, Level: 21 Points: 7,948, Level: 21 Points: 7,948, Level: 21
Thanks: Gave 8, Got 78
Also to add, you dont need to spend that much on that cable from Amazon. You can pick an optical cable up for a couple of quid on ebay. There is no loss of quality with cheaper optical cables as they are meerly a fibre optic cable. The signal either gets there or it doesnt so no loss from poor quality materials etc
Ewan154 (18-08-2007)
HTML code is On
