playing mkv
Old 17-08-2007, 1:57 PM   #1
jamesdrake185
Posts: n/a
playing mkv
very quick question , managed to get hold of a copy of the Top Gear special in HD , its in HD and is MKV file, any idea how this can be played on the 360, what conversion is required etc etc
Old 17-08-2007, 2:08 PM   #2
2,511, Level: 11
Points: 2,511, Level: 11 Points: 2,511, Level: 11 Points: 2,511, Level: 11
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 23, Got 17
Re: playing mkv
Hope this helps.
http://www.riverpast.com/en/support/...t/mkv/divx.php
Old 17-08-2007, 5:40 PM   #3
8,371, Level: 21
Points: 8,371, Level: 21 Points: 8,371, Level: 21 Points: 8,371, Level: 21
Thanks: Gave 253, Got 285
Re: playing mkv
http://forums.xbox-scene.com/index.php?showtopic=611163
Just in case you prefer WMV HD format, I used this tutorial and the results were great, it also gives you chance to fit the film onto single or dual layer DVD.
Old 17-08-2007, 11:08 PM   #4
2,303, Level: 11
Points: 2,303, Level: 11 Points: 2,303, Level: 11 Points: 2,303, Level: 11
Thanks: Gave 4, Got 10
Re: playing mkv
If it'll already fit on a blank (if that's how you're going to view it), you could always try Redkawa Videora XBOX360 Converter. It's free, and it has a profile for using the video from an .mkv file, re-encoding the audio so it's compliant with profiles the 360 can use, and re-muxes them back together ready to play with no re-encoding of the video necessary (that is, of course, if the video was encoded with one of the profiles compliant with the 360).
I've done this with a couple of things, and it's worked great. It's also the fastest method (about 10-25 minutes dependin on the length of the file), so no big deal if it doesn't work.
Old 18-08-2007, 7:24 AM   #5
JagoPlasma's Avatar
12,661, Level: 27
Points: 12,661, Level: 27 Points: 12,661, Level: 27 Points: 12,661, Level: 27
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 847, Got 387
Re: playing mkv
i have it in TS format. 8gigs in total and plays fine on a laptop. however not tried it on a 360 or ps3 yet
HTML code is On
