Track disappears!!!!!
Old 17-08-2007, 11:52 AM   #1
thedeadlysub
Posts: n/a
I got the three rings of death last week and took my 360 back to Gamestation and they swoped it for me for a new one (great service) I kept my hard drive.
Since I have had the new 360 I have had a few problems.
First off the time is an hour behind and won't let me change it (v strange)
When I turn the console on it won't autosign in my profile where my old one would, can you change this?
The biggest problem is when playing Forza and racing on the nordschleife the track disappears half way around!!!! Is this a problem with the disk or the console again!
Thanks for your help in advance
Old 17-08-2007, 11:58 AM   #2
6,803, Level: 19
Points: 6,803, Level: 19 Points: 6,803, Level: 19 Points: 6,803, Level: 19
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 152, Got 206
Re: Track disappears!!!!!
I have never had any of these problems so it sounds like it maybe the console, it could also be the Hard Drive though. Have you tried playing Forza without the HD connected?
Old 17-08-2007, 12:03 PM   #3
2,394, Level: 11
Points: 2,394, Level: 11 Points: 2,394, Level: 11 Points: 2,394, Level: 11
Thanks: Gave 12, Got 14
You can't change to clock when you're connected to Xbox live, check you've got daylight savings enabled.
Yep, go into your profile settings
Not sure on this, maybe try another copy of the game if you can
thedeadlysub (17-08-2007)
Old 17-08-2007, 12:10 PM   #4
Conspicuous Member
21,068, Level: 35
Points: 21,068, Level: 35 Points: 21,068, Level: 35 Points: 21,068, Level: 35
Activity: 31.1%
Activity: 31.1% Activity: 31.1% Activity: 31.1%
Thanks: Gave 751, Got 1,105
i had the same problem with forza graphics all weird mine ended up looking like a ps1 game huge parts of the track just big black squares also when loading up i was getting a fuzzy screen with like loadsa different colours my xbox is now been repaired again i only had that one a week it was a replacement i would phone customer services half the time the game wouldnt load aswell scda was doing the same i could not recieve and send messages the only game that worked ok was halo 2,also it wasnt just the one track a few of them did it.
Old 17-08-2007, 12:29 PM   #5
3,197, Level: 13
Points: 3,197, Level: 13 Points: 3,197, Level: 13 Points: 3,197, Level: 13
Thanks: Gave 8, Got 31
I had the same problem with the time, had daylight saving enabled but was still an hour out. All I did was change the time zone, exit, went back in and switched back to GMT and problem solved.... V Odd
HTML code is On
