Modified Xbox 360 - Pros and Cons?
Thread Closed
Old 14-07-2007, 1:11 PM   #1
3,262, Level: 13
Points: 3,262, Level: 13 Points: 3,262, Level: 13 Points: 3,262, Level: 13
Thanks: Gave 17, Got 13
Anyone got any info on modded Xbox 360's?
I've heard they get auomatically banned when updating software on Xbox Live unless they have a certain version of Ultra flashed on them?
Somebody is offering me an Xbox 360 modded but I'm wary of not being able to play on Live... It's pretty cheap though at £140...
Shall I take it? Is there a way to unblock banned systems?
Old 14-07-2007, 1:17 PM   #2
6,434, Level: 19
Points: 6,434, Level: 19 Points: 6,434, Level: 19 Points: 6,434, Level: 19
Thanks: Gave 19, Got 41
Re: Modified Xbox 360 - Pros and Cons?
Once a 360 is banned its banned for life, it will still work fine but you will not be able to use it on live. The one and only advantage of a modded or flashed 360 is it allows you to use backups on the machine, nothing more nothing less so its not as usable as say a modded original xbox.
Old 14-07-2007, 1:22 PM   #3
Thanks: Gave 49, Got 123
Apart from no xbox live, I dont think MS will touch if you need to send it in for repair.
Old 14-07-2007, 1:25 PM   #4
176, Level: 2
Points: 176, Level: 2 Points: 176, Level: 2 Points: 176, Level: 2
Thanks: Gave 0, Got 15
I don't think it's worth getting one to be honest, as there are more cons than pros... imo
Old 14-07-2007, 3:02 PM   #5
7,358, Level: 20
Points: 7,358, Level: 20 Points: 7,358, Level: 20 Points: 7,358, Level: 20
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 12, Got 134
I would love it if the hackers could sort out ripping the games to the hard drive, and then playing them from it.
This would get rid of the noise from the DVD drive, which really, really gets on my nerves.
I genuinely would not pirate any games, I would just love to have a quieter 360.
Old 14-07-2007, 3:12 PM   #6
3,262, Level: 13
Cool maybe I'll give it a miss as ideally I wanted it to play Forza 2 online against/with my brother.
I've had another offer of an Xbox 360, hard drive, wireless control, lead etc... yet it's Japanese.
The guy says because of this it's region free... But yet again would it work OK on xbox live? Anyone here got a Jap version?
Thanks!
Old 14-07-2007, 3:30 PM   #7
10,786, Level: 24
Points: 10,786, Level: 24 Points: 10,786, Level: 24 Points: 10,786, Level: 24
Thanks: Gave 41, Got 146
The japanease version will work on Live, but since not all games are region free, a lot of UK games will not work on the console.
Old 14-07-2007, 4:00 PM   #8
3,262, Level: 13
So basically the guys lying by saying it works region free? I've done a search on google and can only find that some games are region free... Nothing about region free consoles.
Does anyone here have a Jap system?
Am I right in thinking this would also need a power convertor?
Old 14-07-2007, 4:11 PM   #9
Conspicuous Member
24,126, Level: 37
Points: 24,126, Level: 37 Points: 24,126, Level: 37 Points: 24,126, Level: 37
Activity: 28.3%
Activity: 28.3% Activity: 28.3% Activity: 28.3%
Thanks: Gave 1,624, Got 1,190
You must have some crazy friends, one with a Mod 360 and another with a Jap
Just stay away from them both
Old 14-07-2007, 4:30 PM   #10
3,262, Level: 13
Not friends... Just people I've selling Xbox 360s that I've sourced through the net.
The search goes on for a 360!
Old 14-07-2007, 4:32 PM   #11
58,076, Level: 58
Points: 58,076, Level: 58 Points: 58,076, Level: 58 Points: 58,076, Level: 58
Activity: 22.1%
Activity: 22.1% Activity: 22.1% Activity: 22.1%
Thanks: Gave 1,342, Got 1,898
If I was buying today I would possibly consider an Asian console due to cheap games from playasia(nearly always $39.90 or $44.90). Not to be confused with the Japan version though, the NTSC/J Japan games are a different kettle of fish from the NTSC/J Asian ones, with later release dates & often a higher price than even the UK Pal games.
Be careful what you buy in other words. By the way most of the Asian version 360 games come in English language, some are region-free so will play on any console but not all, EA for instance are always region-locked.
Old 14-07-2007, 5:08 PM   #12
10,474, Level: 24
Points: 10,474, Level: 24 Points: 10,474, Level: 24 Points: 10,474, Level: 24
Thanks: Gave 7, Got 40
I'd be more worried about the fact it now has no warranty. A 360 with no warranty is bound to end in tears.
Old 14-07-2007, 5:25 PM   #13
13,755, Level: 28
Points: 13,755, Level: 28 Points: 13,755, Level: 28 Points: 13,755, Level: 28
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 132, Got 191
I think your looking in the wrong places. Hunt around and you'll find brand new core packs for around £150.
Old 14-07-2007, 5:38 PM   #14
CDR CDR is offline
6,112, Level: 18
Points: 6,112, Level: 18 Points: 6,112, Level: 18 Points: 6,112, Level: 18
Activity: 0.7%
Thanks: Gave 245, Got 319
John Lewis are selling their Core systems for £130. They will also price match their other stores if your local one isnt at that price, and they will also mail order from your nearest store (So i've read).
see here (A HotUKDeals thread).
Old 14-07-2007, 5:56 PM   #15
3,262, Level: 13
Sounds good I'll have a look! Thanks.
Old 14-07-2007, 6:06 PM   #16
4,039, Level: 14
Points: 4,039, Level: 14 Points: 4,039, Level: 14 Points: 4,039, Level: 14
Thanks: Gave 32, Got 130
Does M$ detect the region of the 360 being used and where it's being used? If so, wouldn't you get banned for that?
Old 14-07-2007, 6:14 PM   #17
44,497, Level: 51
Points: 44,497, Level: 51 Points: 44,497, Level: 51 Points: 44,497, Level: 51
Thanks: Gave 108, Got 1,460
Whether they can or not I can't answer but if they can then they are not bothered about it. I've used my original US Xbox on live as well as my US Xbox 360 for years and never had a problem. A lot of others have done the same.
Old 14-07-2007, 9:33 PM   #18
3,262, Level: 13
Managed to win an auction online core system with memory card - £142 delievered on ebay. Plus comes with the box. Fingers crossed it works ok.
Annoying thing is somebody just offered me a Core system, memory card, and PGR3 for £115! Already payed for the ebay item so I couldn't do anything. DOH!
Old 14-07-2007, 9:35 PM   #19
13,768, Level: 28
Points: 13,768, Level: 28 Points: 13,768, Level: 28 Points: 13,768, Level: 28
Activity: 20.3%
Activity: 20.3% Activity: 20.3% Activity: 20.3%
Thanks: Gave 369, Got 830
You can buy a brand new core for £150
Old 14-07-2007, 9:44 PM   #20
3,262, Level: 13
Boots website is out of stock and don't include shipping which is £20. That's £170 straight away.
Haven't found any links to £150 brand new consoles with free delivery.
most places are still about £180 without delivery!
Old 14-07-2007, 9:49 PM   #21
44,497, Level: 51
I'd still rather pay a few pounds more for a new one especially when it comes to the 360.
Old 14-07-2007, 9:57 PM   #22
3,262, Level: 13
Judging from ll the hitec stuff in your sig you can afford to.
I bought a second hand one 'cos I'm on a budget!
Old 14-07-2007, 10:05 PM   #23
44,497, Level: 51
Well all that has been purchased over a number of years and from hard earned money and at the expense of other things I wanted to spend it on. I appreciate that some people will be on a budget but I still would not buy a second hand 360 and would rather wait until I've saved some money to buy a new one. The only time I would even consider buying one is if it was from a personal friend. There are just too many issues with the 360 to risk buying a second hand one.
Old 14-07-2007, 10:33 PM   #24
10,355, Level: 24
Points: 10,355, Level: 24 Points: 10,355, Level: 24 Points: 10,355, Level: 24
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 186, Got 415
Got to agree with Moogle . Have often thought about importing a US 360 ,but the issue of reliability has always put me off . By the same token I would never buy a 2nd hand one .And I am not loaded either ..but sometimes cheap works out more expensive in the long run.
Old 14-07-2007, 10:49 PM   #25
AlertedEncore
Posts: n/a
I have a NTSC j Asia 360,works perfectly with my UK XBL account and i have no problem playing online game, but you can only run either ntsc j or region free games, pal wont work.
The big advantage being that NTSC j (asia) games are half and in some cases three times cheaper than the UK RRP, plus 99% are in English.
As for modded 360s,steer clear of them, if they have not already been banned they will be, and once that happens you will have lost half of the benefits of having a 360.
Old 14-07-2007, 11:03 PM   #26
176, Level: 2
Surprisingly, everyone i know that has got a US 360 has not had a single problem with their machines....
Yet all my friends who have PAL ones....are left crying....
Old 14-07-2007, 11:11 PM   #27
44,497, Level: 51
Well my previous US 360 got the three dreaded red rings of light after 18 months. My Elite is my second 360.
Old 14-07-2007, 11:17 PM   #28
176, Level: 2
Well my previous US 360 got the three dread red rings of light after 18 months. My Elite is my second 360.
Really??? What did you do with it?
How does the warranty work with US machines that are here in the UK?
Old 14-07-2007, 11:32 PM   #29
44,497, Level: 51
I still have it. I haven't decided what to do with it. The warranty on import consoles is not valid here. I'm considering trying to get MS here to fix it anyway. It might be worth a try now there is the 3 year warranty regards 3 red rings. I have heard of other people getting import consoles repaired under warranty here but I don't know if there is any truth in it. Who knows MS technicians may not realize it's an import console.
Old 14-07-2007, 11:36 PM   #30
176, Level: 2
I've never heard of being able to get an import console repaired over here. But then again it's worth a shot.
I once tried it with my US PSP, however once i gave them the serial number over the phone they knew it was a US one...and said no chance....
It's amazing how MS have had to start offering a 3yr warranty...who would have thought...
Thread Closed
HTML code is On
