Help please! Trying to get HD through my Philips HD LCD TV
Old 25-10-2006, 3:53 PM   #1
Djdfine
Posts: n/a
Smile Help please! Trying to get HD through my Philips HD LCD TV
Hi guys, sorry if this has been covered before but I was just wondering if someone could help me. I just received my Xbox 360 Premium and I'm going to try and attempt to get it working in HD format on my Screen. I have the Philips 26PF4310 Display:
http://www.p4c.philips.com/files/2/2...10_pss_eng.pdf
Basically it doesn't have any component inputs and only a single DVI input with no VGA, I was wondering whether it would be possible to use one of these:
http://cgi.ebay.co.uk/DVI-I-M-To-3-R...QQcmdZViewItem
with the component HD cable that came with premium package and then plug that into the DVI port in my LCD TV? If not would i therefore need to purchase a VGA HD lead and a DVI-I to VGA converter? If both of these solutions are viable which one is likely to give me the best display on my screen? Many thanks in advance!
Old 25-10-2006, 4:14 PM   #2
2,959, Level: 12
Points: 2,959, Level: 12 Points: 2,959, Level: 12 Points: 2,959, Level: 12
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 1, Got 5
Re: Help please! Trying to get HD through my Philips HD LCD TV
I use a VGA to DVI convertor and used a VGA cable. Works a treat.
Djdfine (25-10-2006)
Old 25-10-2006, 5:50 PM   #3
5,303, Level: 17
Points: 5,303, Level: 17 Points: 5,303, Level: 17 Points: 5,303, Level: 17
Thanks: Gave 20, Got 4
i have a very similar model but i came with cable that was dvi to red green blue i just plugged them into my componant lead xbox came with usin straight thru barrels and for audio i got a splitter to bring L+R sound into the single 3.5mm jack on the back for audio in
Old 25-10-2006, 10:11 PM   #4
11,946, Level: 26
Points: 11,946, Level: 26 Points: 11,946, Level: 26 Points: 11,946, Level: 26
Thanks: Gave 79, Got 41
yep i got the same telly, if you buy the official vga cable it comes with the necessary adapter for audio and just get a vga to dvi adapter from maplins or something and your sorted
Djdfine (07-11-2006)
HTML code is On
