Sony KDL-26S2010 ghosting
Old 25-10-2006, 1:19 PM   #1
10,068, Level: 24
Points: 10,068, Level: 24 Points: 10,068, Level: 24 Points: 10,068, Level: 24
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 123, Got 144
Anyone with the same tv having ghosting problems? I'm using the VGA connection and theres a bit of ghosting. You sort of don't notice it after you been playing a while tho.
There seems to be ghosting on freeview as well on channels with a weaker signal.
Old 25-10-2006, 1:37 PM   #2
Bales1983
Posts: n/a
Re: Sony KDL-26S2010 ghosting
All fine on my set mate, im using component.
Cannot see any ghosting on freeview either.
maybe the settingso n the tv is it still in vivid mode?
Lee
Old 25-10-2006, 1:53 PM   #3
10,068, Level: 24
Activity: 0.8%
Got it standard mode, even tried custom turning off all the extra features.
I found turning on noise reduction makes it ghost very bad.
HTML code is On
