VGA to DVI adaptor
Old 25-10-2006, 12:10 PM   #1
tom71
Posts: n/a
VGA to DVI adaptor
MY LG TV only has one DVI input and no VGA socket. Can i use a VGA to DVI adaptor as i find the composite picture throught the TV too dark on my 360????
Tom
Old 25-10-2006, 12:19 PM   #2
16,091, Level: 30
Points: 16,091, Level: 30 Points: 16,091, Level: 30 Points: 16,091, Level: 30
Thanks: Gave 38, Got 205
Re: VGA to DVI adaptor
That depends, is it a DVI-I socket or DVI-D?
Old 25-10-2006, 12:34 PM   #3
2,796, Level: 12
Points: 2,796, Level: 12 Points: 2,796, Level: 12 Points: 2,796, Level: 12
Thanks: Gave 29, Got 5
Tom
What model is it? I have a LG RZ32LZ50 with one DVI port. I use a VGA to DVI converter and it is fine.
Pete
Old 25-10-2006, 12:37 PM   #4
Illustrious Member
30,260, Level: 42
Points: 30,260, Level: 42 Points: 30,260, Level: 42 Points: 30,260, Level: 42
Activity: 26.0%
Activity: 26.0% Activity: 26.0% Activity: 26.0%
Thanks: Gave 53, Got 1,271
Tom
I hope you mean component as composite is the worst possible connection you can use.
HTML code is On
