component and vga together
Old 24-10-2006, 1:24 PM   #1
5,872, Level: 18
Points: 5,872, Level: 18 Points: 5,872, Level: 18 Points: 5,872, Level: 18
Thanks: Gave 26, Got 4
is it possible to use vga for watching dvd's as well asusing component for playing games without having to switch over the cables or can you only have one set of leads in at a time?
many thanks
Old 24-10-2006, 1:35 PM   #2
Illustrious Member
30,260, Level: 42
Points: 30,260, Level: 42 Points: 30,260, Level: 42 Points: 30,260, Level: 42
Activity: 26.0%
Activity: 26.0% Activity: 26.0% Activity: 26.0%
Thanks: Gave 53, Got 1,271
Re: component and vga together
Only one at a time.
Old 24-10-2006, 1:45 PM   #3
31,132, Level: 43
Points: 31,132, Level: 43 Points: 31,132, Level: 43 Points: 31,132, Level: 43
Thanks: Gave 105, Got 155
I'd like my Xbox to output both, you could do it with a VGA - Component coverter but I can't find one anywhere.
Old 24-10-2006, 2:11 PM   #4
5,872, Level: 18
so a component converter would do it?
Old 24-10-2006, 4:50 PM   #5
31,132, Level: 43
The way I see it is you use the VGA lead, go into a VGA splitter and convert one of the outputs into Component.
I could do it the other way (Component to VGA) now but that's not what I need. You could do this if it's what works for you.
HTML code is On
