Picture slightly offset on my new LCD TV
Old 24-10-2006, 9:48 AM   #1
jabberwock1977
Posts: n/a
Last night I was playing Rainbow Six: Las Vegas on my new Toshiba 37WLT66. WOW! Anyway... I noticed the pic was a bit offset - you can see your "visor markings" on the screen and I could see the right edge but the left must have been about an inch offscreen. Anything I can do?
Old 24-10-2006, 9:49 AM   #2
Houghsx's Avatar
10,576, Level: 24
Points: 10,576, Level: 24 Points: 10,576, Level: 24 Points: 10,576, Level: 24
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 729, Got 436
Re: Picture slightly offset on my new LCD TV
How have you got it connected to the TV.
What resolution are you running it at?
Old 24-10-2006, 9:54 AM   #3
bluejmc2005's Avatar
312, Level: 3
Points: 312, Level: 3 Points: 312, Level: 3 Points: 312, Level: 3
Thanks: Gave 297, Got 151
Im guessing you have it set up via VGA? if so, set resolution to 1024x768 then use tvs controls to make it widescreen and hey presto - perfect.
Old 24-10-2006, 9:56 AM   #4
Houghsx's Avatar
10,576, Level: 24
Activity: 5.7%
Now why didnt I put it like that lol
Old 24-10-2006, 9:57 AM   #5
jabberwock1977
Posts: n/a
Sorry, should have said. VGA (Official cable) and resolution 1360x768. I did wonder whether changing resolution could affect it as I'm not really sure which res I should be using at the moment. (any advice there)
Incidentally, does anyone know why one of the resolutions (1280 by 720, I think) produces a green picture? Is that expected?
Old 24-10-2006, 10:00 AM   #6
jabberwock1977
Posts: n/a
Great, thanks chaps. And bluejmc2005, I think I recognize you from Rllmuk and you've helped me out before!
Old 24-10-2006, 10:08 AM   #7
Conspicuous Member
21,528, Level: 35
Points: 21,528, Level: 35 Points: 21,528, Level: 35 Points: 21,528, Level: 35
Activity: 22.3%
Activity: 22.3% Activity: 22.3% Activity: 22.3%
Thanks: Gave 4, Got 1,393
The Tosh will display at 1360x768 (16:9) no matter what it says in the manual, then use the TV to centre the picture. 1024x768 (4:3) set to widescreen just stretches the picture, to test this put in a DVD and watch how short and fat everyone one is.
Old 24-10-2006, 10:19 AM   #8
9,585, Level: 23
Points: 9,585, Level: 23 Points: 9,585, Level: 23 Points: 9,585, Level: 23
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 78, Got 90
When i play my original XBOX which does pog through my VGA it comes through as green (all the blacks are green), and no I don't know how to change it. But just so you know it is 'normal' for that TV!
Old 24-10-2006, 10:49 AM   #9
312, Level: 3
np mate i had the same problem, and someone here told me exactly what i just told u and im all sorted now. games and dvds look awesome.
Old 24-10-2006, 10:55 AM   #10
312, Level: 3
I have mine at 1024 x 768, set to 16:9 on the 360. it displays a perfect picture on games and dvds, centrered and certainly with no stretching!
Old 24-10-2006, 11:14 AM   #11
9,830, Level: 23
Points: 9,830, Level: 23 Points: 9,830, Level: 23 Points: 9,830, Level: 23
Thanks: Gave 236, Got 63
I also have the 37WLT66 and was just wondering if you guys have tried the component cable? If so, which do you prefer?
I actually use the components and have never tried the VGA. I know a lot of it is also down to personal preference but i'm lovin' the PQ through component. Cheers
Old 24-10-2006, 11:20 AM   #12
312, Level: 3
I found it too dark, and just prefer VGA
HTML code is On
