Opitcal connection on HD lead
Old 18-04-2006, 8:47 PM   #1
5,578, Level: 17
Points: 5,578, Level: 17 Points: 5,578, Level: 17 Points: 5,578, Level: 17
Just bought a Premium 360.
Went to connect my optical lead but it's a very loose connection. Theres no click. If i just touch it comes out. I have had to use some tape to keep it in. Has anybody else had any similar experiences. I cant figure out if thats normal on all leads or should I take the lead back to the shop where I bought it.
Old 18-04-2006, 9:00 PM   #2
3,761, Level: 14
Points: 3,761, Level: 14 Points: 3,761, Level: 14 Points: 3,761, Level: 14
Thanks: Gave 6, Got 72
Common problem, its a design fault in the official MS leads, some optical connectors work better than others though.
Old 18-04-2006, 9:06 PM   #3
4,895, Level: 16
Points: 4,895, Level: 16 Points: 4,895, Level: 16 Points: 4,895, Level: 16
Activity: 0.5%
Activity: 0.5% Activity: 0.5% Activity: 0.5%
Thanks: Gave 33, Got 56
No, your optical lead is almost certainly not the problem in this case. For more info, have a look at this thread that I started a while back, dealing with exactly the same issue:
http://www.avforums.com/forums/xbox-360/324356-optical-audio-cable-360-why-wont-fit.html#post2718299
Hope that helps!
Old 18-04-2006, 11:40 PM   #4
5,578, Level: 17
Thanks Croker, that was helpful.
One day I'll change the lead, but for now I'll improvise. Incidentally the optical lead is the same one I've been using on my old Xbox for years.
Old 19-04-2006, 12:07 AM   #5
4,902, Level: 16
Points: 4,902, Level: 16 Points: 4,902, Level: 16 Points: 4,902, Level: 16
Thanks: Gave 6, Got 1
My joytech optical lead for the original Xbox is pretty loose, but the optical lead I got for PS2 actually fits quite nicely
HTML code is On
