Can you play Halo 2 using the VGA cable?
Old 18-04-2006, 10:11 AM   #1
6,158, Level: 18
Points: 6,158, Level: 18 Points: 6,158, Level: 18 Points: 6,158, Level: 18
Thanks: Gave 1, Got 0
Question Can you play Halo 2 using the VGA cable?
I will be using my 360 connected to a CRT monitor (for the moment!) using a VGA cable, can anyone tell me if I will be able to play Halo 2?
Martin.
Old 18-04-2006, 10:51 AM   #2
19,560, Level: 33
Points: 19,560, Level: 33 Points: 19,560, Level: 33 Points: 19,560, Level: 33
Activity: 27.7%
Activity: 27.7% Activity: 27.7% Activity: 27.7%
Thanks: Gave 757, Got 722
halo 2 yes, halo CE no.
Old 18-04-2006, 11:37 AM   #3
27,080, Level: 40
Points: 27,080, Level: 40 Points: 27,080, Level: 40 Points: 27,080, Level: 40
Activity: 6.4%
Activity: 6.4% Activity: 6.4% Activity: 6.4%
Thanks: Gave 1,682, Got 2,207
Halo 2 yes but you'll need to use the composite lead to download all the maps and updates first because the vga lead isn't compatible with the update process.
HTML code is On
