Component Lead
Old 17-04-2006, 6:02 PM   #1
simon69's Avatar
5,268, Level: 17
Points: 5,268, Level: 17 Points: 5,268, Level: 17 Points: 5,268, Level: 17
Thanks: Gave 43, Got 5
Component Lead
I need an extension for my component lead, its a few metres short, has anyone any recomendations?
Old 17-04-2006, 7:57 PM   #2
Conspicuous Member
51,181, Level: 55
Points: 51,181, Level: 55 Points: 51,181, Level: 55 Points: 51,181, Level: 55
Thanks: Gave 382, Got 418
You could get some couplers and some more lead and extend it that way, cheap from Maplin.
Old 17-04-2006, 10:45 PM   #3
Miyazaki's Avatar
49,918, Level: 54
Points: 49,918, Level: 54 Points: 49,918, Level: 54 Points: 49,918, Level: 54
Thanks: Gave 709, Got 869
move the console?
That is probably your best bet to retain image quality.
Old 17-04-2006, 11:06 PM   #4
dodger747's Avatar
10,895, Level: 25
Points: 10,895, Level: 25 Points: 10,895, Level: 25 Points: 10,895, Level: 25
Thanks: Gave 210, Got 218
As long as your not extending by a stupid amount [tens of meteres] than it shouldn't make a noticable difference to your PQ...
HTML code is On
