Anyone with a Plasma and Xbox360 please look in...
Old 17-04-2006, 5:29 PM   #1
anakin373
Posts: n/a
I've recently bought the new Panasonic px60 (42") and am blown away by the pic quality with all sources including 360. However, there seems to be a small issue with what I can only describe as green ghosting on fast moving high constrast scenes (i.e black/white). check out post #23 on the following thread for some video clips showing the effect: PX60 - Blurring / Green tinge
Now another forum meber (nh3com) tried his 360 on a number of differnet plasma screens instore and noticed the same effect on all (he didn't check the model numbers but he did check on Hitachi, Pioneer, Samsung, Panasonic and jvc)
So really I'd like to know from all you plasma owners if you see the effect at all - don't be so quick to say NO as many px60/PV500 owners were adamant they didn't, until they looked carefully for it (it's very easy to overlook IMO).
Good scenes to check on - Far Cry, Ghost Recon, Tomb Raider (the demo level - look at the cliff faces and spin around).
Many thanks for your efforts
Old 17-04-2006, 5:33 PM   #2
dodger747's Avatar
10,895, Level: 25
Points: 10,895, Level: 25 Points: 10,895, Level: 25 Points: 10,895, Level: 25
Thanks: Gave 210, Got 218
Wasn't it concluded in the plasma thread that it was a generic plasma trait...?
Old 17-04-2006, 5:36 PM   #3
anakin373
Posts: n/a
well only by 1 person - I'd rather get some more conclusive feedback
I also find it strange that if it is a generic trait, then why hasn't the issue been raised before?
Old 17-04-2006, 5:41 PM   #4
3,275, Level: 13
Points: 3,275, Level: 13 Points: 3,275, Level: 13 Points: 3,275, Level: 13
Thanks: Gave 41, Got 8
I'm running my 360 on a pioneer pdp-436xde and i have never seen that happen. I will have another go tonight once the kids stop watching the ruddy cartoon network.
Old 17-04-2006, 5:59 PM   #5
bob1's Avatar
14,117, Level: 28
Points: 14,117, Level: 28 Points: 14,117, Level: 28 Points: 14,117, Level: 28
Thanks: Gave 34, Got 145
What is the standard lead you get with the 360? my brother bought one a few weeks back and i'm sure he would let me have it on lone for testing purposes .
Old 17-04-2006, 6:08 PM   #6
anakin373
Posts: n/a
thansk for checking guys - I'm using the official component leads (they come asa standard with the premiumpack) on 720p.
Old 17-04-2006, 6:16 PM   #7
13,302, Level: 27
Points: 13,302, Level: 27 Points: 13,302, Level: 27 Points: 13,302, Level: 27
Activity: 13.3%
Activity: 13.3% Activity: 13.3% Activity: 13.3%
Thanks: Gave 24, Got 42
heres some clips showing the effect guys
Old 17-04-2006, 6:17 PM   #8
stevemdavies's Avatar
4,354, Level: 15
Points: 4,354, Level: 15 Points: 4,354, Level: 15 Points: 4,354, Level: 15
Thanks: Gave 8, Got 14
I have read elsewhere that a green blur is a trait of plasma displays. The only time i have seen the effect though was when watching sin city on dvd - lots of fast moving white on black and even then it was only very slight - nothing compared to what is in those video clips. Haven't experienced it all using my 360.
Old 17-04-2006, 6:19 PM   #9
emporer's Avatar
12,307, Level: 26
Points: 12,307, Level: 26 Points: 12,307, Level: 26 Points: 12,307, Level: 26
Activity: 16.6%
Activity: 16.6% Activity: 16.6% Activity: 16.6%
Thanks: Gave 1,325, Got 1,231
i have a pv500 and i think that you need to run the plasma in if its new as this makes a hell of a difference, ive used hi def material on mine since i got it and after around 300 hours on the right settings things just improve and the pic becomes more stable in my opinion
Old 17-04-2006, 6:25 PM   #10
dodger747's Avatar
10,895, Level: 25
Well I've got a PX60 but haven't used my 360 on it yet...
But having seen the posted vids I'll have a test of it tomorrow. Have you tried changing your cable/settings as it may be this that is the source of the problem?
Old 17-04-2006, 6:50 PM   #11
9,041, Level: 22
Points: 9,041, Level: 22 Points: 9,041, Level: 22 Points: 9,041, Level: 22
Thanks: Gave 7, Got 96
Those vids are mine guys, and to answer a few of the questions I'm using component cable, have tried 1080i and 720p, have tried rgb scart cable, have tried lots of settings including no colour at all, I can't get rid of the green blur ( yes the blur is still green even with colour off!). Hopefully it IS faulty ( never wished for something to be faulty before! ).
Old 17-04-2006, 7:09 PM   #12
11,438, Level: 25
Points: 11,438, Level: 25 Points: 11,438, Level: 25 Points: 11,438, Level: 25
Thanks: Gave 129, Got 50
I've just watched those clips and it is evident on them.
I've now tried my 360 but it doesn't seem to happen. I'm using a Pioneer PDP505XDE.
Old 17-04-2006, 7:09 PM   #13
4,938, Level: 16
Points: 4,938, Level: 16 Points: 4,938, Level: 16 Points: 4,938, Level: 16
Thanks: Gave 8, Got 9
Hi there, let's hope we have more success here. But I am still convinced this a known plasma problem. Also because "nh3com" tested the 360 on different plasma screens and they all showed the same effect according to him... I also still think that one does not notice this problem if one hasn't been told about it... That's my theory anyway Please keep us posted if your problem has been solved.
Old 17-04-2006, 7:25 PM   #14
anakin373
Posts: n/a
The effect in those videos is far more pronounced than what is evident on my screen - so you may see a much fainter version of it. If you can try the Tomb Raider demo, please do as the cliff-faces at the beginning are quite tell tale if you move whilst looking at them.
Can you also let us know how long you've had your screen and what games you tested it with?
Old 17-04-2006, 7:53 PM   #15
Conspicuous Member
51,248, Level: 55
Points: 51,248, Level: 55 Points: 51,248, Level: 55 Points: 51,248, Level: 55
Thanks: Gave 382, Got 418
I have rum my PV500 for nearly a year now with xbox hi-def and xbox 360 since launch and I have never noticed this.
There is no point me looking for it as I would have noticed it by now after hunderds of hours.
Old 17-04-2006, 7:56 PM   #16
spadge
Posts: n/a
do any of u guys get retention on dark scenes with xbox360 ive got a 50"lg plasma and if something bright is on a dark background like on condemned theres like a ghostin effect its really annoying tv running at 720p with contrast reduced to 50
Old 17-04-2006, 8:06 PM   #17
11,438, Level: 25
Hi m8, I've had my Pioneer for about a year and a half. I've tried it on Ghost Recon and PGR3.
I'll have a quick look on Tomb Raider later this evening.
Old 17-04-2006, 8:21 PM   #18
2,837, Level: 12
Points: 2,837, Level: 12 Points: 2,837, Level: 12 Points: 2,837, Level: 12
Thanks: Gave 7, Got 4
I have it - TH42PX60, about 150 hours viewing. Only noticed it with Tomb Raider so far (only because its been mentioned on these forums, would not have noticed it otherwise). Using Joytech VGA cable.
Old 17-04-2006, 9:05 PM   #19
anakin373
Posts: n/a
I don't mean to doubt what you're saying mate, but 2 people have already confirmed this effect is present on their PV500, which makes sense as it's almost identical to its successors the PX60/600 models...
Would you do me a big favour and please check the scene on the tomb raider demo - as I said before, it really is hard to spot unless you're looking for it.
The only other reason I can imagine you don't see it is because your screen was already properly run in by the time you got your 360 - whihc is good news for the rest of us I hope
Old 17-04-2006, 9:16 PM   #20
3,440, Level: 13
Points: 3,440, Level: 13 Points: 3,440, Level: 13 Points: 3,440, Level: 13
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 19, Got 16
I have the Panny PW6, whilst I can see green speckling (green dots moving about) on dark areas of the screen as long as I'm about 3 inches from the screen, when looking at it from a reasonable distance (6-8ft away for a 42" screen) blacks look black and I do not notice the effect described by the OP. Neither do I have any ghosting effect noticed by Spadge.
As far as 'running in' my screen, I admit I was really paranoid about this aspect and made sure that my contrast and brightness were -20 on both until 200 hours were past, screen was still perfectly watchable at these settings but once the 200 were up I used a dvd to setup the screen properly and its been like that ever since.
So in short - No - not noticed it before and don't see it now when looking.
Old 17-04-2006, 9:25 PM   #21
3,540, Level: 13
Points: 3,540, Level: 13 Points: 3,540, Level: 13 Points: 3,540, Level: 13
Activity: 2.8%
Activity: 2.8% Activity: 2.8% Activity: 2.8%
Thanks: Gave 35, Got 29
Just double checked on my LG 42PX5D just in case I hadn't noticed it before.
Tried Ghost Recon and Tomb Raider as suggested and I'm not getting any ghosting at all.
Old 17-04-2006, 9:42 PM   #22
anakin373
Posts: n/a
Hi mate
thanks for checking - couple of questions: 1) how long have u had ur plasma and 2) did you view the example videos posted before you checked? it's not really ghosting as such becuase you don't see it anywhere else apart from those few high contrast scenes I mentioned...
Old 17-04-2006, 10:15 PM   #23
11,438, Level: 25
anakin373, quick update for you. I tried the Tomb Raider demo but don't get it on that either.
But be aware, as I mentioned earlier I've had my Pioneer for about a year and a half so it's definately been run in already.
Old 17-04-2006, 10:33 PM   #24
Daddy k's Avatar
14,159, Level: 28
Points: 14,159, Level: 28 Points: 14,159, Level: 28 Points: 14,159, Level: 28
Activity: 17.2%
Activity: 17.2% Activity: 17.2% Activity: 17.2%
Thanks: Gave 378, Got 286
nothing like that on my px11 42 plasma, connected via standard componant. have a good tweak with the settings inc colour temps,
Old 18-04-2006, 12:56 AM   #25
mickymcd's Avatar
5,136, Level: 16
Points: 5,136, Level: 16 Points: 5,136, Level: 16 Points: 5,136, Level: 16
Thanks: Gave 80, Got 37
tried the listed games and tombradider demo no green ghost on edges i do get a slight quick blur when panning on tomb raider looking at rocks but only slight no tearing or colour bleed etc.Using relisys plasma and vga m$ cable tried on component too all ok
Old 18-04-2006, 7:37 AM   #26
3,540, Level: 13
Activity: 2.8%
Hi mate
Hi m8
1) Had my plasma for just over two months.
2) Yes, I watched the videos first, then tried it with high contrast scenes.
Old 18-04-2006, 8:07 AM   #27
Conspicuous Member
51,248, Level: 55
OK will have a look
Old 18-04-2006, 9:04 AM   #28
anakin373
Posts: n/a
Thanks for4 all you efforts guys
Just an update - nh3com who took his 360 down to his local store checked it on the following makes: Hitachi, Pioneer, Samsung, Panasonic and jvc (unfortunately no model numbers) and found the green edge present on all of them...
I really can't understand why some are seeing them and others are not
Old 18-04-2006, 9:12 AM   #29
4,938, Level: 16
I'm afraid some have just better eyes
Old 18-04-2006, 9:13 AM   #30
Conspicuous Member
51,248, Level: 55
I can see it on my PV500, it must have 1000 hours on it, it has been ISF'd and I do see it on the Tomb Raider demo when looking carefully, it is on high contrast areas.
HTML code is On
