Connecting 2.1 speakers
Old 02-03-2006, 3:00 AM   #1
ftogpx
Posts: n/a
Hi guys, i'm thinking of getting the Logitech z2300 speakers
http://www.logitech.com/index.cfm/pr...CONTENTID=9372
I was wondering how i would connect them to the 360. Apparently they come with a video game adapter:
http://www.logitech.com/index.cfm/pr...CONTENTID=9584
But i cant see any similar connections on the 360?
Old 02-03-2006, 8:50 AM   #2
13,312, Level: 27
Points: 13,312, Level: 27 Points: 13,312, Level: 27 Points: 13,312, Level: 27
Activity: 54.2%
Activity: 54.2% Activity: 54.2% Activity: 54.2%
Thanks: Gave 1, Got 523
Which cable are you using with your 360. The standard (composite) cable, the component cable, and the VGA cable all come with stereo audio out on phono connectors.
The only cable which doesn't is the SCART cable.
Steve
Old 02-03-2006, 3:19 PM   #3
ftogpx
Posts: n/a
ah, that's the answer then - i'm using a rgb scart cable
looks like i need to splash out and go for 5.1 then.
Old 02-03-2006, 3:45 PM   #4
13,312, Level: 27
Activity: 54.2%
What is your display device? If you ditch your RGB SCART cable, you will be dropping to composite unless your device has component inputs.
I've got a workaround for you.
Get one of those crappy two in to one SCART splitters (splitter, *not* switch).
Plug one end into your TV, and then plug your XBOX cable into one of the sockets. Into the other socket, you can plug a Scart > 2 x Phono adapter or cable which you can then connect to your logitech speakers.
Steve
HTML code is On
