Go Back   AVForums.com > Gaming > Xbox Gaming > Xbox 360
Today's price checkPowered by
Microsoft Xbox 360 Elite (120GB)
Microsoft Xbox 360 Arcade
Mass Effect 2
Microsoft Xbox 360 Premium HDMI Edition (60GB)
Mass Effect 2: Collectors Edition
Mass Effect 2
Microsoft Xbox 360 Premium HDMI Editi...
Call of Duty: Modern Warfare 2
Bioshock 2
Mass Effect
FIFA Soccer 10
Aliens vs. Predator
 More...Prices updated February 9th at 6:30pm and include delivery.
Old 04-02-2006, 2:42 PM   #1 (permalink)
Thanks: Gave 15, Got 31
Speed Touch 716 WL: Strict NAT
Can anyone help me please? I know there might be some port forwarding to do, but i dont know where to start!
AVRocky is online now   Reply With Quote
Old 04-02-2006, 3:00 PM   #2 (permalink)
Thanks: Gave 3, Got 5
Try turning on UPnP if its available.
harrinp1 is offline   Reply With Quote
Old 04-02-2006, 3:10 PM   #3 (permalink)
I did. No affect
Old 04-02-2006, 4:32 PM   #4 (permalink)
Old 04-02-2006, 4:39 PM   #5 (permalink)
Thanks: Gave 11, Got 29
I take it you have tried setting up you 360 as a DMZ?
That is what I have always done (ie with xbox and 360) and it seems more reliable that way.
smokingreen is offline   Reply With Quote
Old 04-02-2006, 4:45 PM   #6 (permalink)
Whats a DMZ and how do i do that?
Old 04-02-2006, 4:49 PM   #7 (permalink)
Thanks: Gave 118, Got 63
search and you will find the ports you need to forward...avoid DMZ is the last resort!
Jordans Norks is offline   Reply With Quote
Old 04-02-2006, 5:06 PM   #8 (permalink)
I dont know how to forward ports using this!
Old 05-02-2006, 12:37 PM   #9 (permalink)
Thanks: Gave 97, Got 205
Yes I had the same problem with Be Unlimited. This is what you need t do:
Open Network Connections
Right click on the icon on your gateway & go properties
Click Setting
Click Add
Name Xbox(192.168.1.6X:3074) 3074 UDP
IP: 192.168.1.6X
Port: 3074 UDP
Port: 3074 UDP
Ok
x signifies the number for your IP address for 360 & I already know you are on the Be network so it will mostlikely be 64 or 65. this will work. I also advise that on xbox you let it know to always use this Ip it will save you ahving to enter all this in if IP switches
"There are 10 types of people in this world. Those who understand and those who don't."
Magus is offline   Reply With Quote
Soi (05-02-2006)
Old 05-02-2006, 3:04 PM   #10 (permalink)
Click Setting
Click Add
IP: 192.168.1.6X
Port: 3074 UDP
Port: 3074 UDP
Ok
Genius at work, much Kudos mate
FIFA 10 Pre-Ordered
Modern Warfare 2 Pre-Ordered
Halo 3: ODST
Pre-Ordered
Assassins Creed 2
Pending further information
Old 05-02-2006, 4:24 PM   #11 (permalink)
When i download demo's, half way through i get a message saying the download could not be completed. It basically pauses itself or something. Its not the NAT, its open.
And i've got the screensaver disabled. What else could it be?
FIFA 10 Pre-Ordered
Halo 3: ODST
Pre-Ordered
Assassins Creed 2
Old 06-02-2006, 4:36 PM   #12 (permalink)
Lately, i've been getting disconnected quite frequently..like every 30minutes. But this time, after i was disconnected i noticed that the Gateway Icon had dissapeared when its always there.
It's a problem because im having trouble using my Xbox. Can anyone help?
FIFA 10 Pre-Ordered
Halo 3: ODST
Pre-Ordered
Assassins Creed 2
Old 06-02-2006, 4:57 PM   #13 (permalink)
Once again as politely as I can try searching the forums before posting
All the information / trouble shooting steps you can try are available this way.
Old 06-02-2006, 4:58 PM   #14 (permalink)
You have joined my world of frustration with Be. I ahve spent endless hours on the phone with India (i.e their tech team). I have even gone to the extent of buying a wifi card (to no avail) & formatting my c: drive then windows). They have been of no help but I will part some of my wisdom that had resulted in me pulling all my hair out & now I am bold!!
1. Update the lan drivers on your pc
2. On usb you will have more consistent connection
3. Right click on your lan icon for router...disable....then enable (works a treat)
4. On your lan icon enter manual DNS...I have the setting at home but u can phone them for it
5. Same on usb if using usb
6. Stop using file sharing cos that's when the problems arose for me
7. If you call them they will say that they are putting you on a more stable connection which basically means they will put you on an ADSL line instead of ADSL2+
Do point 1. then 4 then 3 & you should be okay...if all else fails after this, reset the router with a pin holding it till the power light goes red & the other lights switch off (par from the light that shows connection with pc & 360 if on) & see what happens.
Disabling & then enabling is very effective to regain connection
Old 06-02-2006, 4:59 PM   #15 (permalink)
by the way you need to forward the following ports:-
It's ports 3074 (both TCP & UDP) and 88 UDP you need!
try this first as it's quickest. (nearly as quick as searching for "port forwarding" on this forum)
716, nat, speed, strict, touch
HTML code is On
Copyright © 2000-2010 M2N E. & O. E.
