hi-def on tft?
Old 17-01-2006, 7:50 PM   #1
4,929, Level: 16
Points: 4,929, Level: 16 Points: 4,929, Level: 16 Points: 4,929, Level: 16
Thanks: Gave 1, Got 0
hi-def on tft?
i have just bought the official xbox 360 cable presumming i would get an awesome quality picture on my tft , oh how i was wrong i am using a CTX S762a 17" tft screen
and im using 1280x1024 res everything looks totally crap! infact it looks worse than my tv! everything is washed out and seems colourless and also looks like it has no AA im not sure what to do at this point im gutted got my cable my setup is all good what can i do ? anyone else having this problem?
Old 17-01-2006, 8:26 PM   #2
4,929, Level: 16
anyone wanna help here?
Old 17-01-2006, 8:31 PM   #3
tjradiohead's Avatar
2,612, Level: 11
Points: 2,612, Level: 11 Points: 2,612, Level: 11 Points: 2,612, Level: 11
Thanks: Gave 53, Got 49
what cable are you using
Old 17-01-2006, 9:13 PM   #4
4,929, Level: 16
vga official m$
Old 17-01-2006, 9:26 PM   #5
DirkTheDaring71
Posts: n/a
Try changing the resolution to 1024x768 and if that doesnt work i suspect a dodgy cable
Good luck with it mate.
Old 17-01-2006, 10:02 PM   #6
44,497, Level: 51
Points: 44,497, Level: 51 Points: 44,497, Level: 51 Points: 44,497, Level: 51
Thanks: Gave 108, Got 1,460
Have you tried your monitor's native resolution ?
Old 17-01-2006, 10:16 PM   #7
6,850, Level: 19
Points: 6,850, Level: 19 Points: 6,850, Level: 19 Points: 6,850, Level: 19
Thanks: Gave 1, Got 3
Unfortunately I think the VGA output from the 360 is a bag of sh1te.
I've used it @ 1280x1024 on a 17" Digimate monitor, and on a DELL 2405 (1920x1200 resolution) with the 360 set to 1368x768, and both made the colour look washed out and jaggies very evident.
The 360 looks great on a Sanyo 73 projector with a 1280x720 res, and I may try it on a 32" widescreen later - it will be using Composite, but I'll do just for an experiment.
I've personally come to that the 360 is only good on panels with 1280x720, it just scales so badly over any connection and looks washed out over VGA.
Old 17-01-2006, 10:45 PM   #8
6,426, Level: 19
Points: 6,426, Level: 19 Points: 6,426, Level: 19 Points: 6,426, Level: 19
Thanks: Gave 18, Got 1
But most games shouldn't have to scale on a TFT set to 1280 X 1024, most add black bars top and bottom.
Old 17-01-2006, 11:11 PM   #9
6,850, Level: 19
The 360 doesn't output the right aspect ratio for Halo 2 over VGA at 1280x1024, PGR3 didn't scale correctly ever for some mad reason.
HTML code is On
