Browser
Old 17-01-2006, 4:32 PM   #1
3,004, Level: 12
Points: 3,004, Level: 12 Points: 3,004, Level: 12 Points: 3,004, Level: 12
Thanks: Gave 9, Got 0
Question Browser
Is there going to be anyway to browse the internet using the 360 ??
Old 17-01-2006, 4:38 PM   #2
BlindDumbdeaf's Avatar
3,268, Level: 13
Points: 3,268, Level: 13 Points: 3,268, Level: 13 Points: 3,268, Level: 13
Thanks: Gave 30, Got 9
Highly unlikely, as Live is a 'gardened network'. It is possible/probable Microsoft will add exclusive sites to marketplace to browse WITHIN their network.
Old 17-01-2006, 5:22 PM   #3
15,815, Level: 30
Points: 15,815, Level: 30 Points: 15,815, Level: 30 Points: 15,815, Level: 30
Thanks: Gave 37, Got 216
The latest OXM ( Issue 4 ) States that the 360 will have a browser by 2007!
Batch
Old 17-01-2006, 5:28 PM   #4
5,145, Level: 16
Points: 5,145, Level: 16 Points: 5,145, Level: 16 Points: 5,145, Level: 16
Thanks: Gave 3, Got 1
I believe it when i see it. I don't see the point anyways it would be a bitch to use without a mouse
Old 17-01-2006, 5:37 PM   #5
Lord Potto
Posts: n/a
Batch
If there is I hope there will be an option to uninstall it or disable it - i don't want the security/virus crap from Windoze on my Xbox
Old 17-01-2006, 5:38 PM   #6
Michaelknell's Avatar
9,868, Level: 23
Points: 9,868, Level: 23 Points: 9,868, Level: 23 Points: 9,868, Level: 23
Thanks: Gave 43, Got 17
Guess how we solve that problem?????
HTML code is On
