Female connection on the VGA
Old 17-01-2006, 2:25 PM   #1
yaris123
Posts: n/a
Does anyon know if the joytech vga end of the lead is female??
Old 17-01-2006, 2:31 PM   #2
4,900, Level: 16
Points: 4,900, Level: 16 Points: 4,900, Level: 16 Points: 4,900, Level: 16
Thanks: Gave 17, Got 4
No it's Male, just like the official MS one - If you are wanting to connect to a normal monitor which does not have a removable VGA lead (which is what i am assuming you want to do)
you will need a 15 Pin F-F convertor like this one:
http://www.maplin.co.uk/module.aspx?...42954&doy=17m1
Hope this helps
Dave
Old 17-01-2006, 2:57 PM   #3
2,756, Level: 12
Points: 2,756, Level: 12 Points: 2,756, Level: 12 Points: 2,756, Level: 12
Thanks: Gave 68, Got 30
Thanks mate I was wanting one of those but couldn't find one anywhere, thanks a lot :-)
Old 17-01-2006, 4:53 PM   #4
13,302, Level: 27
Points: 13,302, Level: 27 Points: 13,302, Level: 27 Points: 13,302, Level: 27
Activity: 13.3%
Activity: 13.3% Activity: 13.3% Activity: 13.3%
Thanks: Gave 24, Got 42
The MS official vga lead comes with an adaptor and also phono to jack adaptor also.
better picture i hear too.
HTML code is On
