How do I search properly?
Old 17-01-2006, 9:40 AM   #1
9,165, Level: 22
Points: 9,165, Level: 22 Points: 9,165, Level: 22 Points: 9,165, Level: 22
Thanks: Gave 9, Got 15
How do I use the search on these forums correctly?
For example I know there is a thread which has this as part of its title
"Colour and Screen Settings Thread"
But when I search for this I get back pages and pages of results. How do I search for threads that only contain those words in that order in the title?
I tried this "Colour+and+Screen+Settings+Thread" but this didnt work.
Any searching advice most appreciated.
Old 17-01-2006, 9:58 AM   #2
Dan L's Avatar
18,348, Level: 32
Points: 18,348, Level: 32 Points: 18,348, Level: 32 Points: 18,348, Level: 32
Thanks: Gave 29, Got 98
Is this it?
LE32R41B/LE32R41BD Colour and Screen Settings Thread
Old 17-01-2006, 10:00 AM   #3
50,193, Level: 54
Points: 50,193, Level: 54 Points: 50,193, Level: 54 Points: 50,193, Level: 54
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,070, Got 2,048
Well, if you know that the words you're searching for are in the title, then you can search titles only.
Old 17-01-2006, 10:02 AM   #4
Dan L's Avatar
18,348, Level: 32
Problem is the search/advanced search does not appear to let you search by "exact phrase" so you get hundreds of hits. I may be wrong on this but I had a look and could not find it.
Do an exact phrase search in Google (enclose query in quotes) and prepare to be amazed
HTML code is On
