heat an issue? here's why...
Old 03-12-2005, 3:55 AM   #1
4,910, Level: 16
Points: 4,910, Level: 16 Points: 4,910, Level: 16 Points: 4,910, Level: 16
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 10, Got 46
just found this article
http://translate.google.com/translat...language_tools
check out the power draw and heat of the various task's!
they seemed very high to me,so decided to do some research and came up
with this.
http://www.anandtech.com/cpuchipsets...px?i=2249&p=13
these systems are configured with 1gb of ram and a radeon 800xt.
if the test's done by that german site are correct,then i can see why
the 360 (in such a tiny box)is having heat problems.
i worry for all next gen system's now...........
Old 03-12-2005, 5:17 AM   #2
Toekiller
Posts: n/a
After 5 hours yesterday, my 360 was cool as was the power brick. 360 ontop of Sky Plus ( which stayed on standby ) .
Old 03-12-2005, 2:16 PM   #3
4,910, Level: 16
Activity: 2.7%
i'm glad your 360 is keeping it's cool
but you have got to admit that the 360 is kicking out heat equal to a
high end pc?
i just hope microsoft sort a solution to this problem asap,and that sony
are taking steps to avoid this problem with the ps3
Old 03-12-2005, 2:23 PM   #4
25,795, Level: 39
Points: 25,795, Level: 39 Points: 25,795, Level: 39 Points: 25,795, Level: 39
Thanks: Gave 238, Got 725
When i play PGR3 its like i've installed a air con system rather than a next gen console. I thknk i might of got a special ice cold 360!
Why do M$ need to do anything about it, if the unit works the unit works. if i t ain't broke, don't fix it
Old 03-12-2005, 2:28 PM   #5
SoleFever's Avatar
4,549, Level: 15
Points: 4,549, Level: 15 Points: 4,549, Level: 15 Points: 4,549, Level: 15
Thanks: Gave 29, Got 69
i just hope microsoft sort a solution to this problem asap,and that sony are taking steps to avoid this problem with the ps3
It's not a problem, the only time you would have a problem is if it set on fire . in my experiance the more power something has the more heat it creates and i really dont see the ps3 being any different.
Old 03-12-2005, 4:37 PM   #6
4,999, Level: 16
Points: 4,999, Level: 16 Points: 4,999, Level: 16 Points: 4,999, Level: 16
Thanks: Gave 22, Got 16
When you have a unit this small in size running 3 x 3gig processors, are you suprised at the heat generated?
Old 03-12-2005, 5:37 PM   #7
8,452, Level: 22
Points: 8,452, Level: 22 Points: 8,452, Level: 22 Points: 8,452, Level: 22
Thanks: Gave 114, Got 29
After running for 4 hours straight my 360 was kicking out less heat than my Laptop (P4 2.80 Ghz - 1 Gb Ram) was after an hour!
PS: Power brick was only vaguely warm as well.
Old 03-12-2005, 5:39 PM   #8
4,910, Level: 16
Activity: 2.7%
no,i'm not suprised!that's my point.
my pc is alot less powerfull than a 360 in a larger case and a 360 watt p.s
a 120mm exhuast fan at the front plus another one at the back.
on top of this the cpu and graphic's card each have their own heatsink AND
fan.
the 360 has a heatsink on the cpu and graphic card and 2 rear 60-80mm
fans.
the p.s is around 200 watt.
think i'll wait till they shrink down to 65nm!
Old 03-12-2005, 6:46 PM   #9
2,735, Level: 12
Points: 2,735, Level: 12 Points: 2,735, Level: 12 Points: 2,735, Level: 12
Thanks: Gave 14, Got 3
I heard the best way to keep it cool was to throw it in a bucket of water when playing? :D
Old 03-12-2005, 7:02 PM   #10
4,910, Level: 16
Activity: 2.7%
just move to sweden for the winter!
get's down to -40 should keep it cool
Old 03-12-2005, 7:13 PM   #11
12,056, Level: 26
Points: 12,056, Level: 26 Points: 12,056, Level: 26 Points: 12,056, Level: 26
Thanks: Gave 2, Got 1
Same here, been on now for about 24 hours solid, combination on playing games and downloading content, the 360 has no heat at all and the power supply is only mildly warm on the bottom. If it you wasn't so bl**dy noisy!
Old 03-12-2005, 7:19 PM   #12
4,688, Level: 16
Points: 4,688, Level: 16 Points: 4,688, Level: 16 Points: 4,688, Level: 16
Thanks: Gave 1, Got 0
Mines warm but they do chuck out someheat out the back, like sitting next to
a electric fan heater. Gonna be fun in the summer
HTML code is On
