SDTV stuttering?
Old 03-12-2005, 12:43 AM   #1
JagoPlasma's Avatar
12,661, Level: 27
Points: 12,661, Level: 27 Points: 12,661, Level: 27 Points: 12,661, Level: 27
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 847, Got 387
SDTV stuttering?
i been playing kameo, pgr3 and some 720P vids (ie pdz trailer 720p)
has anyone noticed the game stuttering?
it happens mostly on kameo.
odd thing is when i hooked it upto my monitor at 720P the stuttering was pratically gone.
just so you know i was using the same component cable for sdtv and to my monitor (component to vga convertor)
anyone else notice this? does the 360 struggle with 576i? i mainly play at 60hz
Old 03-12-2005, 12:48 AM   #2
3,016, Level: 12
Points: 3,016, Level: 12 Points: 3,016, Level: 12 Points: 3,016, Level: 12
Thanks: Gave 30, Got 12
This could be interesting, I've posted a few times today about this being a major problem when playing condemned although no one could come up with a reason why it was happening.
I've tried playing in both 50 and 60hz modes but the problems still there.
Edit - thought i'd add that i'm using a sdtv with the xbox connected via composite
Old 03-12-2005, 1:09 AM   #3
3,016, Level: 12
Damn, I just noticed you said kameo was a game that had this problem as well, to be honest if I get it and it's true I might as well just get rid of my 360 as I can't afford a decent tv to get non stuttering gameplay
I hope someones got a solution to the problem though...
Old 03-12-2005, 2:16 AM   #4
2,624, Level: 11
Points: 2,624, Level: 11 Points: 2,624, Level: 11 Points: 2,624, Level: 11
Thanks: Gave 2, Got 9
I have the same stuttering in the Kameo videos (not ingame) but only if the dashboard it set to PAL 50hz. Setting to 60hz fixes it completely. Havent had any problems with other games in either setting. SDTV with the Advanced AV Scart (RGB).
Old 03-12-2005, 3:30 AM   #5
3,089, Level: 13
Points: 3,089, Level: 13 Points: 3,089, Level: 13 Points: 3,089, Level: 13
Thanks: Gave 3, Got 3
i noticed this too
im running 720p using the included component cable, switched to hdtv and plasma detects it as 720p60....pretty much the same even if i set xbox to 480p....plasma is NEC SD
btw, im only playing demo of nba live at the mo but noticed a little bit of stuttering when watching aeon flux 720p trailer as well
Old 03-12-2005, 9:45 AM   #6
3,016, Level: 12
Ok I got kameo today and it plays fine with no stuttering at all just like PGR3, I think my copy of condemned must be bad or something as that's the olnly game I'm having trouble with.
Old 03-12-2005, 9:48 AM   #7
Senior Moderator
UrbanT's Avatar
30,131, Level: 42
Points: 30,131, Level: 42 Points: 30,131, Level: 42 Points: 30,131, Level: 42
Activity: 11.5%
Activity: 11.5% Activity: 11.5% Activity: 11.5%
Thanks: Gave 373, Got 1,397
Am I being daft here? Are there options for you to change from 50hz to 60hz, or is it just game dependant?
Old 03-12-2005, 9:50 AM   #8
3,016, Level: 12
You can change it in the xbox 360 menu if you go to 'PAL settings'
Old 03-12-2005, 11:13 AM   #9
Illustrious Member
30,260, Level: 42
Points: 30,260, Level: 42 Points: 30,260, Level: 42 Points: 30,260, Level: 42
Activity: 26.0%
Activity: 26.0% Activity: 26.0% Activity: 26.0%
Thanks: Gave 53, Got 1,271
I noticed some stuttering while playing Perfect Dark Zero (only the video sequences) but had it set to PAL60hz so I assumed setting it to PAL50hz would get rid of it but it didnt.
I havent noticed any problems in Condemned though.
HTML code is On
