how would you rate the xbox 360 as a dvd player & cd player
Old 02-12-2005, 9:53 PM   #1
7,281, Level: 20
Points: 7,281, Level: 20 Points: 7,281, Level: 20 Points: 7,281, Level: 20
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 39, Got 8
When I eventually get my paws on one these two things are very important. How does it play music/dvd and what is it in comparision to ie toshiba sd
Old 02-12-2005, 11:11 PM   #2
3,065, Level: 13
Points: 3,065, Level: 13 Points: 3,065, Level: 13 Points: 3,065, Level: 13
Thanks: Gave 14, Got 13
its a bit blocky on dark parts of picture no where near as good as my pioneer 575 which a shame because if it was as good as the pio i could of used it as an all in one enterainment system ,
Old 03-12-2005, 8:15 PM   #3
Conspicuous Member
20,527, Level: 34
Points: 20,527, Level: 34 Points: 20,527, Level: 34 Points: 20,527, Level: 34
Activity: 9.5%
Activity: 9.5% Activity: 9.5% Activity: 9.5%
Thanks: Gave 86, Got 384
It clips the blacks at 16 . Seems to pass full white range though.
From what I've seen briefly its ok. I don't think the deinterlacing is up to much but its probably as good as a cheap prog scan player.
Fairly clean picture . Colour was accurate.
Old 03-12-2005, 8:42 PM   #4
3,089, Level: 13
Points: 3,089, Level: 13 Points: 3,089, Level: 13 Points: 3,089, Level: 13
Thanks: Gave 3, Got 3
yep, just average for me as well
HTML code is On
