anyone tried streaming from Sony NW-HD5?
Old 02-12-2005, 8:31 PM   #1
5,349, Level: 17
Points: 5,349, Level: 17 Points: 5,349, Level: 17 Points: 5,349, Level: 17
Thanks: Gave 16, Got 5
Still waiting for my 360 as Parcelfarce have decided to take it home for the weekend to give it a test drive.
Anyway, wondered if anybody had hooked up a HD5 to the box? I was wondering if the box recognises the ATRAC media format.
Any ideas?
Cheers,
NookZ
Old 02-12-2005, 9:38 PM   #2
2,917, Level: 12
Points: 2,917, Level: 12 Points: 2,917, Level: 12 Points: 2,917, Level: 12
Thanks: Gave 15, Got 0
I don't really think so has SonicStage packages the mp3 files into a oma file which i don't the xbox360 can read and ATRAC forget about M$ will never support it
Old 02-12-2005, 9:47 PM   #3
tim k
Posts: n/a
well the media center recognises .ts playback when using as extender and that was never confirmed as it isnt a strict ms file type. so im chuffed, maybe u will
Old 03-12-2005, 8:49 AM   #4
7,592, Level: 20
Points: 7,592, Level: 20 Points: 7,592, Level: 20 Points: 7,592, Level: 20
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 49, Got 264
I tried my HD-3 and it didn't work, it couldn't read the .OMA file format!
It was recognised as a storage device so you could still put mp3's straight onto it (no sonicstage conversion) but then u wouldn't be able to play them on the HD-3 . You could also put pictures on there too, but videos won't work - gave it a sneaky try.
P.S. I use the VAIO Music Transfer program for my HD-3, so no need for rubbish sonicstage, just drag & drop!
HTML code is On
