Xbox 360 - Video/Audio Capture - HDMI/Optical?
Old 22-11-2009, 7:36 PM   #1
RandomSniper666's Avatar
3,052, Level: 13
Points: 3,052, Level: 13 Points: 3,052, Level: 13 Points: 3,052, Level: 13
Thanks: Gave 454, Got 300
Hi guys,
I have a Xbox 360 Elite and wanted to figure out some way of connecting it to a recorder or my pc? Xbox is running its video via HDMI to my Dell 24" HD monitor and the sound is going via optical to my Ear Force X4 headphones.
An optical splitter would get the audio going to both ok? but how about the video will a HDMI splitter allow two outputs at same time?
PC is a Dell quad core with a Hauppauge HVR-1200 card that has s-video input, so maybe a new HDMI card would be best? any recommendations? or maybe I should just connect to a standalone recorder?
Old 23-11-2009, 12:38 PM   #2
5,672, Level: 17
Points: 5,672, Level: 17 Points: 5,672, Level: 17 Points: 5,672, Level: 17
Activity: 3.8%
Activity: 3.8% Activity: 3.8% Activity: 3.8%
Thanks: Gave 5, Got 164
you need to look at the PC capture cards and see what connections they take and there cost - I have seen ones with component, but not HDMI but they may be out there.
Old 23-11-2009, 1:22 PM   #3
3,052, Level: 13
Thanks yeah think a new capture card may be the best bet, EarForce X4's have optical out so thats the audio sorted, any ideas on splitting the HDMI signal guys?
HTML code is On
