Originally Posted by killabyte hi, i have a few questions, basically i've got 2 xbox 360s and want to know the answer to a few questions that have been on my mind...
1. can i connect 2 xbox 360s to xbox live using 1 router? |
You can, but only certain routers will be able to run both with an open NAT. I bought a D-Link DIR-825 for this purpose, though I believe the D-Link DIR-2640B does it too.
Originally Posted by killabyte 2. can i run 1 gamertag on 2 seperate consoles at the same time? |
Nope, no way at all. Each console needs a profile with a gold sub logged into it, and a profile can only exist on Live in one place at any one time.
Originally Posted by killabyte 3. can i play a game online if i install one to the HDD and the other console runs the game from CD? |
You need a game in the drive to play it, even if it's installed to the HDD.
Originally Posted by killabyte 4. are you allowed to have 2 xbox 360 registered at one address for the warrenty? |
Yeah, no problem.
Originally Posted by killabyte on question 3, when u run the game from the HDD doesn't it do a check for the CD when its detected the CD and gone through, it doesn't require the CD, so i can take the CD out and put into the other xbox and run from CD? if that makes sense  |
Pressing the eject button when in a game takes it back to dashboard, so no, I'm afraid.
