poor graphics
Old 18-11-2009, 4:05 PM   #1
6,876, Level: 19
Points: 6,876, Level: 19 Points: 6,876, Level: 19 Points: 6,876, Level: 19
Thanks: Gave 109, Got 56
poor graphics
just loaded MW2 and got the message to update the console.
got a completely diffenet blade system and graphic quality is absolute crap!!
what on earth is going on?
Old 18-11-2009, 4:08 PM   #2
50,183, Level: 54
Points: 50,183, Level: 54 Points: 50,183, Level: 54 Points: 50,183, Level: 54
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 1,070, Got 2,048
Re: poor graphics
Well, I'd guess you don't have blades at all now, but the new menu system called NXE (New Xbox Experience). It's an acquired taste for some I guess...but adds functionality and all the old shortcuts are present when you press the guide button.
No idea what you mean about the graphical quality though, you may have a problem if that doesn't look right.
Old 18-11-2009, 4:09 PM   #3
Assured Advertiser
LINDY Chris's Avatar
2,019, Level: 10
Points: 2,019, Level: 10 Points: 2,019, Level: 10 Points: 2,019, Level: 10
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 4, Got 63
Re: poor graphics
Maybe it has reset the display output.
Check the options, do you use component or HDMI?
Best Regards
Chris
LINDY Electronics. Computer, Audio / Video and Home Cinema Cables & Accessories. Over 2,500 products in stock.
Established in 1932. ISO 9001 Certified.
www.lindy.co.uk | Follow us on twitter @LINDYUK and Facebook
Old 18-11-2009, 4:17 PM   #4
11,883, Level: 26
Points: 11,883, Level: 26 Points: 11,883, Level: 26 Points: 11,883, Level: 26
Activity: 29.4%
Activity: 29.4% Activity: 29.4% Activity: 29.4%
Thanks: Gave 562, Got 331
Re: poor graphics
It will look pap depending on your 360 display settings. Some peoples sets dont work well with NXE at anything 720p and below.
Old 18-11-2009, 4:38 PM   #5
6,876, Level: 19
Re: poor graphics
obviously i have not been paying attention!! NXE!!
the box is connected with component through an onkyo 876 amp.
the setting is at 1080i.
my daughter just played a sonic the hedgehog game and it was full of jaggies!
i never had this problem before the update.
regards,.
Old 18-11-2009, 5:04 PM   #6
11,883, Level: 26
Activity: 29.4%
Re: poor graphics
Pop it down to 720p then. Should clear it up.
Also what is your sharpness setting?
On a properly calibrated set, the sharpness is usually between 0-10. Sharpness only really needs to be high on a CRT set.
12 promises (18-11-2009)
Old 18-11-2009, 6:31 PM   #7
6,876, Level: 19
Re: poor graphics
sharpness was at 0% and changed it to 720p.
all is well !................ta very much
Old 18-11-2009, 6:49 PM   #8
11,883, Level: 26
Activity: 29.4%
Re: poor graphics
I was born to help, a PS people off... If I am not doing either of the 2 I am sleeping!
HTML code is On
