Originally Posted by vickysp lol, this is the dilemma Steve and Dao. For my budget i could pick up a Samsung 720p or a budget 1080p but not it seems a Samsung 1080p.
I did come across this 1080p LG on special at Debenhams; LG TVs - LCD 32LF2510 - Debenhams Electricals
Everywhere i am looking Samsung is recommended though. So if getting a Samsung it would need to be a 720p.
I am getting more confused by the minute - and looking at TVS there are so many numbers.   |
I'd probably stick with Samsung as they have a better reputation than LG - at least, I know more people with them and they are all happy that is. If budget does not permit 1080p, get a 720p set. I do a fair bit of design and photography and have been using high resolution displays for years at sizes ranging from 17" - 24" so I notice the difference at any size. I'd say 40" is the sweet spot for me as I can see a lot more flaws in the Sky HD picture on my new 50" plasma compared to my 40" LCD and would say 50" is as big as I will go until higher resolutions are available in a few years (4K).
That said, with a high quality source such as bluray or the xbox360, the picture on the 50" is fantastic and should be equally so on a 32" 720p set. Just thought I'd give you some background on where I'm coming from to reassure you 720p won't be bad by any means. As Dao Fei Long says, he'll likely upgrade it himself in due course.
@schrodingergeek - I think that's a bit of a sweeping statement regarding game mode. It can be used to cover a multitude of sins and some sets indeed suffer less lag and better picture quality outside of their game mode but it is unfair to tar all TV's with the same brush. The point of a game mode is normally to turn off additional processing for a cleaner signal, resulting in less lag (delay between hitting a button on the pad and that being converted to an action on screen - for Vicky's benefit). Some TV's get this wrong but not all.
Granted my V10 is a good model but I notice no difference in lag between the technically accurate THX mode or the game mode which is a little more vibrant which I prefer. I'm sure there are other TV's whose game mode works as advertised.
