Broken LCD
Old 08-09-2009, 12:04 PM   #1
Thanks: Gave 1,761, Got 1,378
Broken LCD
The fruit of my loins has just decided to pull my gaming LCD off my desk , in effect breaking it ( god why did i want kids again )
I'm now using an old BEKO Television , which obviously does not have a VGA port on only scart connection, i need a new cable to play my 360 until the new LCD arrives.
It obviously needs the scart adapter to plug it in to my turd tv , my question is which cable do i need composite or component and where can it be picked up from ? instore as cheap as possible
cheers
Old 08-09-2009, 12:13 PM   #2
11,153, Level: 25
Points: 11,153, Level: 25 Points: 11,153, Level: 25 Points: 11,153, Level: 25
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 904, Got 568
Re: Broken LCD
Havent you got the component cable in the box? you can plug the composite leads on it into the scart block adapter and just use that for now.
Old 08-09-2009, 12:19 PM   #3
Re: Broken LCD
No i don't have a cable Because i sold all my spares out of the elite box at the time i was using a monitor for my gaming so purchased an official VGA cable , so still looking for a cable please
Old 08-09-2009, 12:38 PM   #4
Illustrious Member
45,880, Level: 52
Points: 45,880, Level: 52 Points: 45,880, Level: 52 Points: 45,880, Level: 52
Activity: 87.2%
Activity: 87.2% Activity: 87.2% Activity: 87.2%
Thanks: Gave 1,843, Got 3,281
Re: Broken LCD
you need the composite cable and then a normal composite to scart adapter
Mr Noble (08-09-2009)
Old 08-09-2009, 12:41 PM   #5
50,183, Level: 54
Points: 50,183, Level: 54 Points: 50,183, Level: 54 Points: 50,183, Level: 54
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 1,070, Got 2,048
Re: Broken LCD
Component is HD, composite can go via scart, that's what you want. There's info in the FAQ about the connectionsa available.
Old 08-09-2009, 2:46 PM   #6
Re: Broken LCD
so it is definately composite i need , is component not better and will it not work if using component into scart? had a look at game they want £18 , gonna pick one up on ebay for £5 delivered
Old 08-09-2009, 2:56 PM   #7
Illustrious Member
45,880, Level: 52
Activity: 87.2%
Re: Broken LCD
composite is the yellow connector and there are two phono audio leads that accompany it, the scart adpater has three phono inputs (coloured yellow, red and white) and the scart connector
component is three video connectors (Pb, Pr and Y) and is also often accompanied by two phono audio leads. However there are no cheap or easy component to scart adapters
Old 08-09-2009, 3:01 PM   #8
5,456, Level: 17
Points: 5,456, Level: 17 Points: 5,456, Level: 17 Points: 5,456, Level: 17
Thanks: Gave 168, Got 326
Re: Broken LCD
An RGB Scart cable will give a better picture than composite into a Scart adapter mate
Old 08-09-2009, 3:20 PM   #9
Re: Broken LCD
will this do the trick , item number on ebay: 32042076039
or this (this is the kind i got with a premium i used to own) 260471390473
Old 08-09-2009, 3:56 PM   #10
2,694, Level: 12
Points: 2,694, Level: 12 Points: 2,694, Level: 12 Points: 2,694, Level: 12
Activity: 3.2%
Activity: 3.2% Activity: 3.2% Activity: 3.2%
Thanks: Gave 76, Got 47
Re: Broken LCD
The first one doesn't give anything when I search for that number, but the second will deff work for you
Old 08-09-2009, 4:01 PM   #11
Illustrious Member
45,880, Level: 52
Activity: 87.2%
Re: Broken LCD
Same results here, cant find the first one but the second one will be fine (and is the same type as comes with the console)
Old 08-09-2009, 4:47 PM   #12
Location: Real guitars don't have strings, they have 5 coloured buttons.
28,493, Level: 41
Points: 28,493, Level: 41 Points: 28,493, Level: 41 Points: 28,493, Level: 41
Activity: 12.9%
Activity: 12.9% Activity: 12.9% Activity: 12.9%
Thanks: Gave 616, Got 940
Re: Broken LCD
Play.com (UK) : Joytech XBox 360 Digital AV RGB SCART Cable : Xbox 360 - Free Delivery
Old 08-09-2009, 5:54 PM   #13
Illustrious Member
45,880, Level: 52
Activity: 87.2%
Re: Broken LCD
same effect as the equally priced MS one on the bay
Old 08-09-2009, 5:55 PM   #14
Thanks: Gave 33, Got 65
Re: Broken LCD
if you have a component cable, check the side of the connector block - if it says HDTV/SDTV click it to SDTV and use the three cables that are separated from the rest and just put them into the scart adapter - this works as its how my local gamestation uses it and indeed what i shall be doing temporarily when i move into my new house...
it can be done without buying a new cable if you already have the component video...
thought you'd like to know.
***Ignore me, I completely missed the post aout not having the cable, lol***
Old 08-09-2009, 5:59 PM   #15
28,493, Level: 41
Activity: 12.9%
Re: Broken LCD
But composite is AWFUL. Even for a few weeks I'd spend the money on an RGB cable.
Old 08-09-2009, 6:58 PM   #16
Re: Broken LCD
can't you tell we've all been spoilt by 1080???
HTML code is On
