Help?
Old 07-09-2009, 1:38 PM   #1
1,490, Level: 8
Points: 1,490, Level: 8 Points: 1,490, Level: 8 Points: 1,490, Level: 8
Thanks: Gave 1, Got 0
Help?
I hope you can help I have recently just bought a HD ready tv, the problem is it doesn't have anywhere for me to plug my red, blue and green wires in, this means that I can't play in HD. It has 2 red, 2 white and one yellow port for my wires. Can anybody help ?
It would be much appreciated!
Old 07-09-2009, 1:39 PM   #2
5,356, Level: 17
Points: 5,356, Level: 17 Points: 5,356, Level: 17 Points: 5,356, Level: 17
Activity: 1.2%
Activity: 1.2% Activity: 1.2% Activity: 1.2%
Thanks: Gave 54, Got 38
Re: Help?
What make & model is the TV mate?
Old 07-09-2009, 1:39 PM   #3
Conspicuous Member
21,874, Level: 35
Points: 21,874, Level: 35 Points: 21,874, Level: 35 Points: 21,874, Level: 35
Activity: 15.2%
Activity: 15.2% Activity: 15.2% Activity: 15.2%
Thanks: Gave 190, Got 733
Re: Help?
What model TV do you have?
Does your 360 have an HDMI port?
Old 07-09-2009, 1:42 PM   #4
5,356, Level: 17
Activity: 1.2%
Re: Help?
Good point. If it has the hdmi port in the back of your 360 then you can just run the hmdi cable form the 360 to your tv
Old 07-09-2009, 1:42 PM   #5
1,490, Level: 8
Re: Help?
Digihome 16822 16" 16:9 HD Ready IDTV LCD
Old 07-09-2009, 1:44 PM   #6
1,490, Level: 8
Re: Help?
where abouts is the HDMI port??
Old 07-09-2009, 1:46 PM   #7
5,356, Level: 17
Activity: 1.2%
Re: Help?
On the back of your console under the A/V socket.
Old 07-09-2009, 1:50 PM   #8
1,490, Level: 8
Re: Help?
next to the cable for my router ?
Old 07-09-2009, 1:52 PM   #9
5,356, Level: 17
Activity: 1.2%
Re: Help?
Yes just to the left of that mate
Old 07-09-2009, 1:54 PM   #10
1,490, Level: 8
Re: Help?
yeah i know where you mean!
what now ??
Old 07-09-2009, 1:56 PM   #11
5,356, Level: 17
Activity: 1.2%
Re: Help?
Well if you have the hdmi socket you can use a hmdi lead instead of the AV cable and run it from your 360 to your tv. So you would not need to use the green red yellow ect cables just the one hdmi lead.
Old 07-09-2009, 1:57 PM   #12
1,490, Level: 8
Re: Help?
right will this cable have came with the xbox or will i need to go out and buy one ?
Old 07-09-2009, 2:01 PM   #13
5,356, Level: 17
Activity: 1.2%
Re: Help?
I dont think they all come with the hdmi iirc. If you have the comp lead but have the hdmi port then you can by the hdmi lead. As long as your have the hdmi port.
Jak2911 (07-09-2009)
Old 07-09-2009, 2:02 PM   #14
1,490, Level: 8
Re: Help?
okay! thank you !!!
Old 07-09-2009, 2:05 PM   #15
5,356, Level: 17
Activity: 1.2%
Re: Help?
Always a pleasure. Welcome to AVF by the way
Old 07-09-2009, 2:47 PM   #16
t1m103's Avatar
7,136, Level: 20
Points: 7,136, Level: 20 Points: 7,136, Level: 20 Points: 7,136, Level: 20
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 185, Got 199
Re: Help?
according to a quick google search the tv should have component inputs.
Old 08-09-2009, 1:49 PM   #17
4,060, Level: 15
Points: 4,060, Level: 15 Points: 4,060, Level: 15 Points: 4,060, Level: 15
Thanks: Gave 241, Got 88
Re: Help?
You could also use a VGA cable instead of HDMI (my preference everytime )
About £7 for a 2nd hand one at CEX.
VGA or HDMI should give you a better picture than component anyway.
Can you get a picture of the back of the TV?
Old 08-09-2009, 2:01 PM   #18
5,356, Level: 17
Activity: 1.2%
Re: Help?
My 360 does not have a hdmi socket. Would a VGA lead be batter than the comp one i use now?
Old 08-09-2009, 2:15 PM   #19
4,060, Level: 15
Re: Help?
I'm pretty sure that VGA and HDMI give a very similar picture - Having seen HDMI on a friends TV (same make as mine) I personally prefer my VGA set up but it all comes down to preference.
Check 2.6 in THIS THREAD
Whereabouts are you? Maybe one of us could lend you / show you what its like with a VGA cable?
Old 08-09-2009, 2:20 PM   #20
5,356, Level: 17
Activity: 1.2%
Re: Help?
its just i dont have the hdmi socket and if a vga is better than the standard its worth getting i have the vga on the back on my samsung hdmi tv.
Old 08-09-2009, 2:47 PM   #21
4,060, Level: 15
Re: Help?
I honestly can't remember what standard component looked like on my TV - I can check later for you. I'm pretty sure that VGA is better than component otherwise I wouldn't have bothered changing.
I had the same problem that my old xbox didn't have a HDMI connection but when I got my new xbox with HDMI I still went out and got another VGA cable as I really do prefer it.
Old 08-09-2009, 2:51 PM   #22
5,356, Level: 17
Activity: 1.2%
Re: Help?
How do you set up the sound as i read that it is just for the picture?
Old 08-09-2009, 3:45 PM   #23
2,694, Level: 12
Points: 2,694, Level: 12 Points: 2,694, Level: 12 Points: 2,694, Level: 12
Activity: 3.2%
Activity: 3.2% Activity: 3.2% Activity: 3.2%
Thanks: Gave 76, Got 47
Re: Help?
The cable has red + white phonos as well as the VGA
Old 08-09-2009, 3:55 PM   #24
4,060, Level: 15
Re: Help?
As spocksbeard said here's a pic to show you
You can alos get an adaptor to convert the red + white phono to jack
Old 08-09-2009, 3:57 PM   #25
5,356, Level: 17
Activity: 1.2%
Re: Help?
And this is be better than comp?
Old 09-09-2009, 8:39 AM   #26
5,356, Level: 17
Activity: 1.2%
Re: Help?
Anyone else use VGA?
Old 09-09-2009, 8:54 AM   #27
50,183, Level: 54
Points: 50,183, Level: 54 Points: 50,183, Level: 54 Points: 50,183, Level: 54
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 1,070, Got 2,048
Re: Help?
I've got VGA on my 2nd 360. It's roughly equivalent to component quality, but can be better or worse depending on how your TV handles it.
Old 09-09-2009, 8:56 AM   #28
5,356, Level: 17
Activity: 1.2%
Re: Help?
Argh so wont look much better than the comp lead. As i dont have a hdmi socket.
Old 09-09-2009, 9:26 AM   #29
50,183, Level: 54
Activity: 3.0%
Re: Help?
By comp you mean component, not composite I assume? The quality of connections is roughly:
HDMI > VGA/Component > RGB Scart > Composite
VGA is better for some people than component, but for some component is better than VGA. There is no hard and fast rule, it depends which TV you have and what your personal preference is.
The only sure way to find out is to try yourself.
Old 09-09-2009, 9:32 AM   #30
5,356, Level: 17
Activity: 1.2%
Re: Help?
i have the standard lead. And t samsung 1080i 40 hdmi tv
HTML code is On
