Originally Posted by w124_Coupe ive got all the GH ones for my 360 and love them
today i got RB and wonderd
1 - can i use my wireless singstar mics with it
2 - can i use a normal controller to do the drums
3 - ive got 2 x GH3 guitars, 2 x 360 pads & 2 x singstar mics, can i use all of or any of them to replace the normal drums/mic/stuff
cheers |
In answer to your questions:
1. No, because the Xbox 360 doesn't recognise the SingStar mics as they are not "standard" USB microphone hardware.
2. No.
3. The GH3 guitars will work fine and you will need a controller to be used in conjunction with the USB microphone (I recommend the Logitech Vantage USB mic), but the rest will be no use to you.
Based on your current setup if you wish to play as a 4 player band, you will need to purchase a new microphone and a drum controller (either a Rock Band or Guitar Hero World Tour set).
Hope this helps.
