xbox not seeing files on PC's USB hard drive
Old 12-10-2009, 5:39 PM   #1
3,235, Level: 13
Points: 3,235, Level: 13 Points: 3,235, Level: 13 Points: 3,235, Level: 13
Thanks: Gave 35, Got 9
hi,
finally managed to get my xbox seeing the media on the my PC it only shares files that are on C:\ though, i have a USB hard drive with 2 NTFS partitions and a FAT32 partition. On my PC these are E:\ F:\ and G:\. When i choose music on the xbox i can only see the files on my C:\ drive, is there a way to see the files on the USB hdd?
thanks in advance for your help
steve
Old 12-10-2009, 6:17 PM   #2
15,585, Level: 30
Points: 15,585, Level: 30 Points: 15,585, Level: 30 Points: 15,585, Level: 30
Activity: 16.5%
Activity: 16.5% Activity: 16.5% Activity: 16.5%
Thanks: Gave 1,045, Got 784
Re: xbox not seeing files on PC's USB hard drive
what are u using to stream? windows media player? Tversity?
In either u will have to add the specific folders u want shared so it'll see it.
Main My music folder on C drive must be default and so seeing it. Or mayb that is.lol
Or at least thats how ur post reads, have u selected the drives/or specific folders on the external drive to be shared?
Old 12-10-2009, 6:23 PM   #3
3,235, Level: 13
it's using the standard windows sharing, so i guess its using windows media players sharing. I can see the media in my WMP library on my PC just not on the xbox. Do i need to setup file sharing on the USB drive or does WMP take care of that?
Old 12-10-2009, 8:53 PM   #4
LJx LJx is offline
4,603, Level: 16
Points: 4,603, Level: 16 Points: 4,603, Level: 16 Points: 4,603, Level: 16
Activity: 12.8%
Activity: 12.8% Activity: 12.8% Activity: 12.8%
Thanks: Gave 37, Got 217
plug any usb devices - hard drives, flash etc. directly into the USB ports on the xbox
Old 12-10-2009, 10:03 PM   #5
3,235, Level: 13
the 2 main partitions are NTFS though
