Status Code: 69-80072741 ?? Cant stream.
Old 29-09-2009, 2:19 PM   #1
mpn mpn is offline
7,574, Level: 20
Points: 7,574, Level: 20 Points: 7,574, Level: 20 Points: 7,574, Level: 20
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 777, Got 539
Hi all, have just set up a new router and when i try to stream vids to my 360 i get i get a message saying cany play because it may not be supported and the above status code. It was ok until i installed a new router. I dont know if i need to open ports or anything so advice is appreciated, its a netgear wr2000 router. Thanks
Old 29-09-2009, 3:32 PM   #2
5,155, Level: 17
Points: 5,155, Level: 17 Points: 5,155, Level: 17 Points: 5,155, Level: 17
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 175, Got 72
Re: Status Code: 69-80072741 ?? Cant stream.
what streaming software are you using?
if your not using tversity, give that a try.
or is this being streamed from an NAS?
Old 29-09-2009, 3:50 PM   #3
mpn mpn is offline
7,574, Level: 20
Activity: 2.4%
I connected to my router with a wire and it worked ok, disconnected the wire and it is still ok Will just wait and see what happens
Old 02-10-2009, 1:23 PM   #4
3,226, Level: 13
Points: 3,226, Level: 13 Points: 3,226, Level: 13 Points: 3,226, Level: 13
Thanks: Gave 156, Got 59
I had the same problem and i opened a port which i followed after xbox live suggested this.
Old 03-10-2009, 8:01 AM   #5
2,804, Level: 12
Points: 2,804, Level: 12 Points: 2,804, Level: 12 Points: 2,804, Level: 12
I too have just developed the same problem but the only couple changes I've done are add a another wireless access point to the Network and moved my profile from the hard drive to a memory card!
The 360 is connected to the network by anetwork cable and was streaming fine until about a week ago
Any ideas!
Old 03-10-2009, 11:22 AM   #6
2,804, Level: 12
Sorted - deleted the video files in 360 System memory. Then checked the router set up and found that uPNP was disabled. Enabled it, attempted to play a video on the network, downloaded video system files and it worked!!
