Xbox360 n PC cant see each other - Help
Old 03-09-2009, 3:43 PM   #1
2,016, Level: 10
Points: 2,016, Level: 10 Points: 2,016, Level: 10 Points: 2,016, Level: 10
Ive looked at all the posts here but cant see my probably anywhere. Ok i dont entirely know what im doing so this may not even be possible.
Setup:
PC connect wirelessly to Router
Xbox 360 connected to router by the wire.
Is is possible to do the whole media sharing thing?
If so how?
Ive followed the steps on the xbox website but the PC in media centre cant see the xbox to allow it.
Old 04-09-2009, 10:26 AM   #2
3,226, Level: 13
Points: 3,226, Level: 13 Points: 3,226, Level: 13 Points: 3,226, Level: 13
Thanks: Gave 156, Got 59
Re: Xbox360 n PC cant see each other - Help
I had the same problems but i checked the solutions that xbox give you when you cannot connect on your tv screen, I had to Open a port from my firewall and that did the trick. I use MacAfee Security Center. So you may have to open a port on your firewall.
Old 04-09-2009, 10:28 AM   #3
2,016, Level: 10
Cheers mate.
However out of the blue this morning it has picked them both up so all done.
Old 04-09-2009, 10:44 AM   #4
3,226, Level: 13
Originally Posted by scaryjon View Post
Cheers mate.
No bother. I have found though that some of my Divx's wont play, Error comes uo saying i don't have the proer codec's and gives a number after it. So having to do a bit of re-sorting my dvd collection on my laptop so they can play.
Good to see you got things going.
Old 23-09-2009, 7:25 AM   #5
13,838, Level: 28
Points: 13,838, Level: 28 Points: 13,838, Level: 28 Points: 13,838, Level: 28
Activity: 9.5%
Activity: 9.5% Activity: 9.5% Activity: 9.5%
Thanks: Gave 517, Got 660
I'm having a similar issue using windows 7 RC and windows firewall.
Anyone have any ideas?
Old 24-09-2009, 2:45 PM   #6
mpn mpn is offline
7,574, Level: 20
Points: 7,574, Level: 20 Points: 7,574, Level: 20 Points: 7,574, Level: 20
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 777, Got 539
I have been have trouble over the past few days streaming to my 360. I did have windows 7 rc and it was ok, then it went dodgy. Re installed my laptop back to factory vista but its still the same ??
